Hello,
We are using following code to zoom to specific layer extent,
we are adding a layer using following code,
var aPNsGraphicsLayer = AGSGraphicsOverlay()
var agsBoundaryPolygon: AGSPolygon!
//Polygon co-ordinates array
func addLayerOnArcGisMap(_ Locations: [AGSPoint]) {
let polygonBuilder = AGSPolygonBuilder(spatialReference: AGSSpatialReference.wgs84())
polygonBuilder.addPart(with: Locations)
self.agsBoundaryPolygon = polygonBuilder.toGeometry()
let grapichs: AGSGraphic = AGSGraphic(geometry: self.agsBoundaryPolygon, symbol: self.barrierSymbol(1), attributes: nil)
self.aPNsGraphicsLayer.graphics.add(grapichs) //addGraphic(grapichs)
self.aPNsGraphicsLayer.isVisible = true
// To set zoom to added layer
self.agsMapView.setViewpointGeometry(self.aPNsGraphicsLayer.extent, padding: 50, completion: { (finished) -> Void in
Randomly this is not working and the map showing default zoom, on next attempt, it's working, so is there any way to fix this issue.
