Crash on com.esri.arcgis.agsoperationQueue.serial
331
06-01-2017 05:22 AM
AnkitShah
New Contributor II
Found some crash reports with following crash log, it will be great if you can look into it and provide some details if there is any way to avoid it.
#12. Crashed: com.esri.arcgis.agsoperationQueue.serial
0 libsystem_kernel.dylib 0x183045014 __pthread_kill + 8
1 libsystem_pthread.dylib 0x18310f334 pthread_kill + 112
2 libsystem_c.dylib 0x182fb99c4 abort + 140
3 libsystem_c.dylib 0x182f8e53c basename_r + 314
4 libc++.1.dylib 0x182a68c1c std::__1::mutex::unlock() + 56
5 LAFDBrush_Prod 0x100d10500 Esri_runtimecore::Mapping::Signal_base::empty_() const + 72
6 LAFDBrush_Prod 0x100c62c28 Esri_runtimecore::Mapping::Delegate<Esri_runtimecore::Mapping::Loadable, Esri_runtimecore::Mapping::Load_status>::forward(Esri_runtimecore::Mapping::Loadable&, Esri_runtimecore::Mapping::Load_status) const + 64
7 LAFDBrush_Prod 0x100c62a30 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_without_check_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 196
8 LAFDBrush_Prod 0x100b44cb4 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 180
9 LAFDBrush_Prod 0x100b44e20 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Loadable const&) + 92
10 LAFDBrush_Prod 0x100e4ef0c Esri_runtimecore::Mapping::Signal<Esri_runtimecore::Mapping::Loadable const, Esri_runtimecore::Mapping::Load_status>::operator()(Esri_runtimecore::Mapping::Loadable const&, Esri_runtimecore::Mapping::Load_status) const + 420
11 LAFDBrush_Prod 0x100c62a50 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_without_check_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 228
12 LAFDBrush_Prod 0x100b44cb4 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 180
13 LAFDBrush_Prod 0x100e39060 Esri_runtimecore::Mapping::Service_info_loader<Esri_runtimecore::Mapping::ArcGIS_map_service_info>::handle_response_(std::__1::shared_ptr<Esri_runtimecore::Mapping::Request> const&, unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 192
14 LAFDBrush_Prod 0x100cce4a8 Esri_runtimecore::Mapping::Request_delegator::handle_response(unsigned long long, unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 416
15 LAFDBrush_Prod 0x100cce2a8 Esri_runtimecore::Mapping::Request::handle_response(unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 136
16 LAFDBrush_Prod 0x1008548a4 RT_Request_handleResponse + 140
17 LAFDBrush_Prod 0x1005c5520 -[RTCRequest handleResponse:userDefinedError:error:] + 236
18 LAFDBrush_Prod 0x100718dc0 __71+[AGSRTCRequestDispatcher ags_kickOffCoreRequest:forRequestDispatcher:]_block_invoke.173 + 1040
19 LAFDBrush_Prod 0x100693550 __38-[AGSObservableOperation didComplete:]_block_invoke + 264
20 LAFDBrush_Prod 0x1006075bc ags_runWithMainThread + 76
21 LAFDBrush_Prod 0x10069341c -[AGSObservableOperation didComplete:] + 280
22 LAFDBrush_Prod 0x10068ee7c -[AGSRequestOperation didComplete:] + 396
23 LAFDBrush_Prod 0x10069325c -[AGSObservableOperation finishWithResult:error:] + 148
24 LAFDBrush_Prod 0x100692538 -[AGSRequestOperation finishWithResult:error:] + 700
25 LAFDBrush_Prod 0x1006931b8 -[AGSObservableOperation doCancel] + 72
26 LAFDBrush_Prod 0x10068ecdc -[AGSRequestOperation doCancel] + 380
27 LAFDBrush_Prod 0x1006b17d8 __40-[AGSOperationQueue cancelAllOperations]_block_invoke + 216
28 libdispatch.dylib 0x182f029e0 _dispatch_call_block_and_release + 24
29 libdispatch.dylib 0x182f029a0 _dispatch_client_callout + 16
30 libdispatch.dylib 0x182f10ad4 _dispatch_queue_serial_drain + 928
31 libdispatch.dylib 0x182f062cc _dispatch_queue_invoke + 884
32 libdispatch.dylib 0x182f12a50 _dispatch_root_queue_drain + 540
33 libdispatch.dylib 0x182f127d0 _dispatch_worker_thread3 + 124
34 libsystem_pthread.dylib 0x18310b1d0 _pthread_wqthread + 1096
35 libsystem_pthread.dylib 0x18310ad7c start_wqthread + 4
