Display GPS Heading or rotate map to heading?
3254
10-05-2010 01:46 AM
AndrewEgleton
New Contributor III
Is there a way to show the heading on the GPS location without using Core Location and my own graphic? We are not working in WGS84 so need to keep the transformation that is applied with AGSGPS.
I have been thinking of using AGSGPS for the location and then getting the heading from core location to add my own graphic but I'm not sure if thats possible?
The ideal solution is to rotate the map so the persons heading is always at the top of the screen, but I don't think that possible at the moment?
JeremyBixby
New Contributor III
AndrewEgleton
New Contributor III
Thanks for pointing that out, its useful to know, but I need to find a solution that works when stationary too.
NoureddineEl-zaatari
hello,
were you able to di anything about map rotation,,
thanks for any help
