Hi
I have an issue with displaying GUID type field in the popup. Its getting ignored.
let gdbFeature = Feature as? AGSGDBFeature
var popups = [AGSPopup]()
//At this point i can see all fields including GUID field type
print(gdbFeature)
//After adding into AGSPopupInfo GUID type is getting ignored.
let popupInfo = AGSPopupInfo(forGDBFeatureTable: gdbFeature.table)
var items = popupInfo.fieldInfos as! [AGSPopupFieldInfo]
for fieldInfo: AGSPopupFieldInfo in fieldInfos {
print(fieldInfo.fieldName)
Is there any way to add GUID type field or append those field manually.
Thanks in advance.
I have a similar question. I want to pass a GlobalID as a parameter to a survey123 form. The custom URL does not show the value.
After some trial and error of adding a point in a web map and not seeing the GlobalID value I realized I had to pan the map before I saw it in the custom URL I created. I discovered this by refreshing the table in ArcCatalog after I added the point. I could see that the GlobalID was being created.
