Displaying Current Location on MAP, not Working (when Tiled Layer not added)
6403
11
05-20-2015 12:37 PM
GajaNaik
New Contributor III
no code changes nothing, MyLocation is displayed on MAP when Tiled Layer is added as Base MAP, but when there is no Tiled Layer / Blank with Dynamic Layer , current/My Location  can not be seen (Blue Dot).
its basic code and was working earlier, was notice recently that only without Tiled Layer user can not see Location on MAP... but works fine with Tiled Layer....
GajaNaik
New Contributor III
Hello,
Thanks for your reply.
i did better solution saving Envelope (fullEnvelope) details in respondToLayerLoaded method after Dynamic Layer is loaded.
if its fine with next build, will test the App with Beta version once released.
DavidLednik
Occasional Contributor II
Good that you have a workaround.
I would be interested in your feedback when you have the chance to test our beta release.
regards,
David
