How to get domain values from sub type?
1947
04-05-2018 07:57 PM
BatbayarBazarragchaa
New Contributor III
I've defined sub types for my feature class and some fields have different domain values for each sub type.
And I've exposed it as a feature service and trying to get domain and its values for each different sub type.
But when I get domain (AGSCodedValueDomain) from field (AGSField) it returns same domain for each sub type.
So I've tried to get domain from sub type (AGSFeatureType) but it returns AGSInheritedDomain, which I couldn't figure out how to get coded values.
Arcgis feature service version: 10.4.1
SDK version 100.2.1
Language: Swift
Nicholas-Furness
Update 3 of the runtime (due in the June timeframe) will expose Subtypes through the API.
I'm afraid that in the meantime you'll have to get the metadata from the REST endpoint and parse out the information yourself (as you mention, you'll need to upgrade your server). This code might help point you in the right direction:
func parseSubtypeInfo(forServiceFeatureTable featureTable:AGSServiceFeatureTable) {
    guard let url = featureTable.url else {
        return
    let operation = AGSJSONRequestOperation(remoteResource: featureTable,
                                            url: url,
                                            queryParameters: nil)
    operation.registerListener(AGSOperationQueue.shared()) { (jsonResult, error) in
        guard error == nil else {
            print("Error loading resources: \(error!.localizedDescription)")
            return
        guard let jsonDict = jsonResult as? [String:Any] else {
            print("JSON not a dictionary!")
            return
        guard let subtypeField = jsonDict["subtypeField"] as? String,
            let defaultSubtypeCode = jsonDict["defaultSubtypeCode"] as? Int,
            let subtypes = jsonDict["subtypes"] as? [[String:Any]] else {
                print("Couldn't find Subtype info")
                return
        print("Subtype Field: \(subtypeField)")
        // subtypes is now an Array of subtype definition Dictionaries.
    AGSOperationQueue.shared().addOperation(operation)
Hope this helps,
Nick.
RobertBorchert
Frequent Contributor III
From ArcCatalog export the database as an XML Workspace Document.  Just do schema only.
then open the XML in MS Excel.  While the result will not be pretty.  You can do some simple Analysis and you will be able to find all your Subtypes, each attribute in the subtype, each domain attached to that attribute and each value of the domain.
New Contributor III
So with this solution I have to locally store the domain information on the mobile device and have to release an update when the domain values are updated. So its not a good solution.
It seems like there's another way to get domains from REST service, but its available from Arcgis 10.5, so I have to update my feature service. Its the query domains service but I haven't tried yet:
Query Domains (Feature Service)—ArcGIS REST API: Services Directory | ArcGIS for Developers
Nicholas-Furness
        return
                                            url: url,
            return
            return
                return
Hope this helps,
Nick.
Nicholas-Furness
You might also find this answer useful determining the actual domain that's being inherited in a subtype
ShiminCai
Occasional Contributor III
I'm still on SDK 10.2.5. I use the below funcs to get subtype description domain:
func getSubtypeDescriptionDomain(_ subtypeCode: Int, forDescriptionField subtypeDescriptionField: String, forGDBFeatureSourceInfo gdbFeatureSourceInfo: AGSGDBFeatureSourceInfo) -> AGSDomain
        var domain: AGSDomain!
        for type in gdbFeatureSourceInfo.types
            if((type as AnyObject).typeId as! Int == subtypeCode)
                for (key, value) in (type as AnyObject).domains!
                    if(subtypeDescriptionField == key as! String)
                        domain = value as! AGSDomain
                        return domain
        return domain
The subtypeCode is from the subtype field of a feature class that has subtype defined. The subtypeDescriptionField is the string field name to get domain from for the subtypeCode. The gdbFeatureSourceInfo is an instance of AGSFeatureLayer from a feature service or AGSGDBFeatureTable from a geodatabase downloaded in code from the feature service.
This is to determine if a field is a subtype description field:
func isSubtypeDescriptionField(_ subtypeCode: Int, forFieldName fieldName: String, forGDBFeatureSourceInfo gdbFeatureSourceInfo: AGSGDBFeatureSourceInfo) -> Bool
        var subtypeDescriptionField = false
                for (key, _) in (type as AnyObject).domains!
                    if(fieldName == key as! String)
                        subtypeDescriptionField = true
                        return subtypeDescriptionField
Hope it helps.
Shimin
