How to implement mapView.visibleArea().contains(graphic)?
712
05-23-2017 01:29 PM
NikolayYekimov1
New Contributor III
v10.2.5 had an ability to tell if the mapView contains a graphic:  mapView.visibleArea().contains(graphic.geometry.envelope.center). In v 100.0 there is no contains method for
mapView.visibleArea which is AGSPolygon. It's easy to just take a polygon and start comparing xmin xmax ymin ymax, the caveat is to do it with respect to rotation angle. Any ideas?
Tags (1)
MarkDostal
Thank you for your question!  Take a look at the AGSGeometryEngine class.  That has a method "geometry:containsGeometry", which should do what you want:
guard let visibleArea = mapView.visibleArea else { return }
guard let graphicCenter = graphic.geometry?.extent.center else { return }
let isGraphicInMapView = AGSGeometryEngine.geometry(visibleArea, contains: graphicCenter)
