Hi Rostislav,
It sounds like you are parsing the GeoJSON into polygons that you are adding to a Graphics Overlay.
Unfortunately, Graphics Overlays will always display on top of operational layers by design. However, you can achieve the behavior you're looking for by using a FeatureCollectionTable and FeatureCollectionLayer.
You can use the AGSGraphics that you are currently creating as input to featureCollectionTableWithGeoElements:fields:, since AGSGraphics are AGSGeoElements. However, there is one additional step you will need to take and that is to provide a set of AGSFields to define the shape of the FeatureCollectionTable. While a Graphics Overlay has no schema and the Graphics can each have any collection of Attributes, a FeatureCollectionTable must have a schema defined. So if your polygon graphics have attributes, create a set of Fields that match those attributes and pass that in to create the featureCollectionTable. This also means that all the graphics must have the same shape type (Polygon in your case) and the same attributes.
You can then create a Feature Collection Layer. Here is some sample code that should help. It creates a single large polygon AGSGraphic at 0,0 with two attributes ("ID" and "Created"), and then generates a FeatureCollectionTable. In your code you would of course add many AGSGraphics with polygons generated from the GeoJSON:
class ViewController: UIViewController {
@IBOutlet weak var mapView: AGSMapView!
override func viewDidLoad() {
super.viewDidLoad()
// Do any additional setup after loading the view.
// Provide an API Key to use this sample standalone
// AGSArcGISRuntimeEnvironment.apiKey = "<YOUR API KEY>"
let map = AGSMap(basemapStyle: .arcGISTopographic)
mapView.map = map
addFeatureCollectionLayer(to: map)
mapView.touchDelegate = self
extension ViewController {
func addFeatureCollectionLayer(to map: AGSMap) {
let geoElement = AGSGraphic(
geometry: AGSPolygon(points: [
AGSPointMakeWGS84(0, -10),
AGSPointMakeWGS84(-10, 0),
AGSPointMakeWGS84(0, 10),
AGSPointMakeWGS84(10, 0)
symbol: nil,
attributes: [
"ID":"Shape 1",
"Created": Date()
let fields = [
AGSField(fieldType: .text, name: "ID", alias: "Identifier", length: 255, domain: nil, editable: true, allowNull: false),
AGSField(fieldType: .date, name: "Created", alias: "Created", length: 0, domain: nil, editable: true, allowNull: false)
let layer = createFeatureCollectionLayerFromGeoElements(geoElements: [geoElement], fields: fields)
map.operationalLayers.add(layer)
func createFeatureCollectionLayerFromGeoElements(geoElements: [AGSGeoElement], fields: [AGSField]) -> AGSFeatureCollectionLayer {
let table = AGSFeatureCollectionTable(geoElements: geoElements, fields: fields)
table.renderer = AGSSimpleRenderer(symbol: AGSSimpleFillSymbol(style: .solid, color: .orange, outline: nil))
table.displayName = "My custom GeoJSON table"
let collection = AGSFeatureCollection(featureCollectionTables: [table])
let layer = AGSFeatureCollectionLayer(featureCollection: collection)
layer.name = "My custom GeoJSON layer"
return layer
extension ViewController: AGSGeoViewTouchDelegate {
func geoView(_ geoView: AGSGeoView, didTapAtScreenPoint screenPoint: CGPoint, mapPoint: AGSPoint) {
geoView.identifyLayers(atScreenPoint: screenPoint, tolerance: 12, returnPopupsOnly: false) { [weak self] results, error in
guard let self else { return }
if let error = error {
print("Error identifying: \(error.localizedDescription)")
return
guard let results = results else { return }
for result in results {
self.printIdentifyResults(result: result)
func printIdentifyResults(result: AGSIdentifyLayerResult) {
print(result.layerContent.name)
for geoElement in result.geoElements {
print(geoElement)
print(geoElement.attributes)
for subResult in result.sublayerResults {
printIdentifyResults(result: subResult)
Note that I do have some sample code for parsing GeoJSON geomety into Runtime AGSGeometry and even GeoJSON Features into AGSGeoElements available here, in case that helps, though it sounds like you're already doing that part OK: https://gist.github.com/nixta/8a5637a288ce22501aa086e6b5933adf
Hope this helps.
