Radius of a circle drawn as a polygon
8074
15
08-05-2013 11:10 AM
KunalMehta
New Contributor II
All,
I found this solution to draw a circle as a polygon of 360 points:
-(AGSPolygon*) circleWithCenter:(AGSPoint*)point raduis:(double)radius
    AGSMutablePolygon * p = [AGSMutablePolygon new];
    [p addRingToPolygon];
    int pointsCount = 360;
    double slice = 2 * M_PI / pointsCount;
    for(int i = 0; i<pointsCount;i++){
        double rad = slice * i;
        double px = point.x + radius * cos(rad);
        double py = point.y + radius * sin(rad);
        [p addPointToRing:[AGSPoint pointWithX:px y:py spatialReference:[AGSSpatialReference spatialReferenceWithWKID:4326]]];
    return p;
The question I have is what is the units of the radius passed in? For example, if I want to draw a circle of raduis 10 miles, what value do I pass in? If I pass in 10, it just draws a really huge circle with radius several multiples of 10!
I tried to look into the sdk api docs and could not find much info, so any help will be appreciated.
Nicholas-Furness
Ah. That's a very different question.
You should use Polygon.getCentroid() to get the centerpoint of the circle.
Then use Polygon.getPoint(0,0) to get a Point from the circle and use geometryEngine.distance() between the two points to determine the radius.
That assumes you used the Draw.CIRCLE type when you call draw.activate().
Please note that you appear to be using the draw-end event and it seems that is deprecated in favor of the draw-complete event.
FancyAugustin
New Contributor II
Thank you  this was really useful.
one more clarification.
I saw the below format in tutorial:
distance(geometry1, geometry2, distanceUnit)
geometry.getPoint(0,0)
Object {type: "point", x: -15849192.693999259, y: 10478016.378614787, spatialReference: Object}
geometry.getCentroid()
Object {type: "point", x: -18090547.842482734, y: 10478016.37861477, spatialReference: Object}
How can i proceed with distance function.Sorry i am new to esri map? Can you please clarify this too?
Nicholas-Furness
No problem . The following should get you the radius in meters:
var radius = geometryEngine.distance(geometry.getCentroid(),geometry.getPoint(0,0),"meters");
FancyAugustin
New Contributor II
When i try to add
esri/geometry/geometryEngine
under require in the which i posted before ,it is giving me error saying
Uncaught ReferenceError: require is not defined
Can i get your help on this?
Nicholas-Furness
Probably best to post a question like that over on the ArcGIS API for JavaScript space. But if your previous require statement worked, this will work too. Since you're getting started with the APIs, perhaps take a look at the Develop sections of the DevLabs and Hackerlabs (including the 3.x labs).
FancyAugustin
New Contributor II
Really sorry that was issue in network.
radius:1927212.6012732424
The above radius i got when executed that code.
But is this valid value,i doubt that?
