Subtype doesn't render on iPhone 4
505
10-04-2011 10:29 AM
by Anonymous User
Not applicable
I have an ArcGIS.com map that uses a public map service from our ArcGIS Server.  A key field is stored as a subtype.  The subtype renders in the pop-ups on ArcGIS.com and iPad, however it does NOT render in the pop-ups on the iPhone.
Help?
RussRoberts
Esri Notable Contributor
What are the versions of the app you are using? and.. Can you share publicly this map for a temporary time? I would like a second to check it out and if it is an issue I will check to see if this issue has been fixed for the next release.
Russ
by Anonymous User
Not applicable
Apologies!  Although I thought I had updated, when looking to answer your question about which version, I noticed there was another upgrade (2.0.1) and after I upgraded, the subtypes rendered in the pop-up.  Thanks.
RussRoberts
Not a problem. Glad to hear your problem has been resolved!
Cheers
Russ
