Connect to SQL Server Database dynbamically
2904
02-15-2013 10:23 AM
jp
New Contributor II
I am developing a Runtime application that enables user selected Access or SQL database to connect. According to the concepts page this is possible through datasource or querydatasource but only through the workspaceID from a ArcGISDynamicMapServiceLayer.
I was able to open Access database from a custom python script tool. Is this possible to do the same with SQL database?
I cannot use CreateDatabaseConnectoin tool because its not supported in ArcGIS Runtime. Another way is using 'pyodbc' library.
Has anybody else ideas or experience with this kind of workflow?
Thanks!
MichaelBranscomb
Esri Frequent Contributor
Are these Access / SQL Server databases actually Geodatabases? Or would you like to join a non-spatial table from the database to a spatial dataset in another datasource? I'm assuming it's the latter... you could take a look at this earlier post which discusses using the JoinDataSource: http://forums.arcgis.com/threads/74686-Joining-Database-with-Map-Layer?
Cheers
Mike
jp
New Contributor II
Thanks Mike!
I looked at the posting you referred to but I found ArcGIS Runtime doesn't support workspacefactorytype of SQL Server database. So this might not work as desired.
I can think of only looping through the data and editing the a default table everytime the application is connected to a new database. Since its not possible to connect to SQL server in ArcGIS Runtime. Actually I need to attach a mdf file to SQL Server.
Is there another way?
Thanks!
Cheers
Mike
