Hi,I made a script to get the Z value for a list of terrains files at a specific X,Y, but the script can not be converted into a GPK because of the methods i'm using.Does anybody have another good simple approach to do this, which can be packaged into a GPK ?I will need to replace MosaicToNewRaster_management and GetCellValue_management, but i'm not sure how! I was thinking on using the Raster class and/or some NumPy approach, but can't figure out how to do it. Anybody have some leads on how to achieve this ?import arcpy
from arcpy import env
from arcpy.sa import *
# Check out the ArcGIS Spatial Analyst extension license
arcpy.gp.overwriteOutput = 1
print "Start"
# original terrain data
terrainOne = r"C:\MyFolder\TerrainFiles\ned_25581390.flt";
terrainTwo = r"C:\MyFolder\TerrainFiles\ned_57214367.flt";
tempRasterFolder = r"C:\Myfolder\scratch.gdb"
tempRaster = "tempRaster"
arcpy.MosaicToNewRaster_management(terrainOne + ";" + terrainTwo, tempRasterFolder, tempRaster, number_of_bands=1, mosaic_method="LAST")
# location to get Elevation from
source = arcpy.Point( )
source.X = -87.6815094515746
source.Y = 41.811765962018300
# define string
sourceString = str(source.X) + str(" ") + str(source.Y)
sourceElevationString = arcpy.GetCellValue_management(tempRasterFolder +"\\"+ tempRaster, sourceString)
#sourceElevationString = arcpy.GetCellValue_management(terrainOne, sourceString)
# get elevation
result = sourceElevationString.getOutput(0)
if result != 'NoData':
source.Z = float(result)
# print (converted meters to feet)
print str(source.Z)
print str(source.Z / 0.3048)
else:
print "value (x,y) not found on raster"
