What should I do to distribute ESRI WPF control?
1366
02-28-2014 12:03 PM
ArthurFofanov
What should I do to distribute ESRI WPF control that I use in Windows WPF application. I don't want to install ArcGIS Runtime for WPF on clients machines, but if I copy only ESRI assemblies to client PCs I'm getting some licensing exception.
BKuiper
Occasional Contributor III
You will need the Esri "Deployment Builder" that is part of the SDK installation and deploy the package together with your application.
ArthurFofanov
Is there any document or step by step instruction on how to do this? When I run deployment tool I'm generation some folder with ESRI components I don't understand where my application (assemblies and .exe) should go. And what is the minimum set of components that should go on user PC.
BKuiper
