We have a performance question on WPF "GraphicsLayer". Our desktop application uses ArcGIS Runtime SDK for WPF 10.2.
We are trying to determine the maximum number of graphics(points) that we can put on a graphicsLayer. We would also like to
know if any of the characteristics of the graphics are more costly than others, such as Maptip, attributes, zoom function, etc.
Also, if we spread them (the graphics) across multiple layers, what limits and
performance impacts (positive or negative) should we be aware of using multiple layers for these
large number of graphics?
Here is a snipppet from our applicaiton.
Scenario:
For some number of approximately 1 to 50 sets of groups of graphics
(with 1 to 200 groups in each set having 1 to 20 graphics per group) to be drawn on the map:
(potentially as much as 200,000 points)
Code:
Step 1:
for (<each group...>)
AddPointsToGraphicsListDispatch(....);
Step 2:
AddGraphicsToLayerDispatch(...);
// Step 1: Adding graphics to a List
private bool AddPointsToGraphicsListDispatch(...)
List<Graphic> AddGraphicsList = GraphicsListParam;
Graphic gr = new Graphic
Geometry = _mercator.FromGeographic(new MapPoint(longitudeLocal, latitudeLocal)),
Symbol = newSymbol, // newSymbol is a SimpleMarkerSymbol (point)
MapTip = CreateToolTip(userData, latitudeLocal, longitudeLocal, imeiData, imsiData, phoneNumberData, pair.ResultId, target.TargetId,
requestId, pair.MLCTime.ToString(), reqType, null, GetCallingNumber(target.TargetId, requestId), null, accuracy),
gr.Attributes["Latitude"] = latitudeLocal;
gr.Attributes["Longitude"] = longitudeLocal;
gr.MouseEnter -= GraphicOnMouseEnter;
gr.MouseEnter += GraphicOnMouseEnter;
gr.MouseLeftButtonUp += GraphicMouseLeftButtonUp;
gr.SetZIndex(zOrder);
AddGraphicsList.Add(gr);
//second graphic
Graphic uigraphic = new Graphic
Symbol = symbol,
requestId, pair.MLCTime.ToString(), reqType, null, null, null, accuracy)
uigraphic.SetZIndex(zOrder);
zOrder = +zOrder;
AddGraphicsList.Add(uigraphic);
// Step 2:
// Remove old graphics from map
// Add new graphics from graphics list to graphicsLayer
private bool AddGraphicsToLayerDispatch(List<Graphic> GraphicsListParam, List<Graphic>> PrevGraphicsListParam)
List<Graphic> AddGraphicsList = GraphicsListParam; // the list where graphics were added earlier
Dictionary<Tuple<Int32, Int32>, List<Graphic>> PrevGraphicsList = PrevGraphicsListParam; // previously added graphics were saved in a list for removal from map
if (null == (List<Graphic>)(PrevGraphicsListParam[new Tuple<int, int>(RequestId, TargetRef.TargetId)] = (this.Dispatcher.Invoke((new Func<List<Graphic>>(() =>
var graphicsLayer = MainMap.Layers[Layer] as GraphicsLayer;
if (null != PrevGraphicsList && PrevGraphicsList.ContainsKey(new Tuple<int, int>(RequestId, TargetRef.TargetId)))
foreach (Graphic gr in PrevGraphicsList[new Tuple<int, int>(RequestId, TargetRef.TargetId)])
// Remove old graphics before adding new ones
if (graphicsLayer.Graphics.Contains(gr))
graphicsLayer.Graphics.Remove(gr);
PrevGraphicsList.Remove(new Tuple<int, int>(RequestId, TargetRef.TargetId));
// Add new graphics to the graphicsLayer
graphicsLayer.Graphics.AddRange(AddGraphicsList);
graphicsLayer.Refresh();
if (zoom) ZoomToLocate(_latitude, _longitude);
// Save the new list for the next removal
return AddGraphicsList;
