Hi, I am trying to generate a token via a java web app. It works on some servers, but on others I get a response that I don't expect (happens via the app and when posting directly in a browser:
Request looks like this:
or this:
Response looks like this:
{"ssl":{"supportsSSL":true,"sslPort":6443}}
as opposed to what I expect:
{"token":"U4rudliz0r6yQG2esK1Mcha8utQ-6XQVJG5iTHH8we2HHx1JR6MA52g3FYXuMVCX","expires":"1538503485453"}
The response doesn't indicate it's an error. So I'm a little confused.
Also, if, on the problem servers, I go to the UI for generating a token (http://localhost:6080/arcgis/admin), it generates a token correctly.
Is there some sort of configuration in ArcServer that needs setting? I don't see anything blatantly different when I compare working vs non-working server configurations.
Thanks in advance
