Generating Token By URL Request From ArcGIS Portal?
4018
03-26-2020 01:10 AM
MehdiPira1
I'm trying to generate a token from a Portal url. It generates a token when pasting this link into a web browser:
https://portalUrl/sharing/rest/generateToken?&f=json
but when I run this code:
function getToken(portalUrl, username, password) {
  var xmlhttp = new XMLHttpRequest();
  var url = "https://portalUrl/sharing/rest/generateToken?username=username&password=password&f=json";
  xmlhttp.open("POST", url, false);
  xmlhttp.send();
  if (xmlhttp.status == 200) {
    var responseJSON = JSON.parse(xmlhttp.responseText)
    if (responseJSON && !responseJSON.error) {
      return responseJSON.token;
    } else {
      return "ERROR";
  } else {
    return "ERROR"
I get an error.
and I've created this in XHR code too:
var xhr = new XMLHttpRequest();
xhr.withCredentials = true;
xhr.addEventListener("readystatechange", function() {
  if(this.readyState === 4) {
    console.log(this.responseText);
xhr.open("POST", "https://portalUrl/sharing/rest/generateToken?username=username&password=password&f=json");
xhr.send();
and this throws the following error:
{"error":{"code":400,"message":"Unable to generate token.","details":["POST request should not contain username and password in the query string."]}}
Any ideas or help is appreciated.
Thank you.
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Mehdi,
If you have Windows Authentication enabled on the web adaptor, you will need to go around the web adaptor and specify the server name where portal is installed (i.e. server.domain.com:7443/arcgis). Ex:
import requests, json
# Disable warnings
requests.packages.urllib3.disable_warnings()
username = "gis\jskinner"
password = "********"
tokenURL = 'https://server.domain.com:7443/arcgis/sharing/rest/generateToken/'
params = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'https://server.domain.com'}
r = requests.post(tokenURL, data = params, verify=False)
response = json.loads(r.content)
token = response['token']
print(token)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
If Windows Authentication is not enabled, you specify the web adaptor URL (i.e. server.domain.com/portal):
# Disable warnings
tokenURL = 'https://server.domain.com/portal/sharing/rest/generateToken/'
StrathconaBTS
New Contributor III
I also ran into this. I included the username and password in the body of the request instead of the header and that solved the issue!
EG
