Thanks Robert,I am attaching my code with this reply.
Bulbul
the js I am using is
Script: productionWellsView313.js
/* Script updated to AMD-style formatting */
var map;
var navToolbar;
require([
"esri/config", "esri/map", "esri/arcgis/utils", "esri/geometry/Extent", "esri/SpatialReference",
"esri/InfoTemplate", "esri/dijit/Legend",
"esri/tasks/LegendLayer", "dojo/on", "dijit/registry", "esri/dijit/BasemapGallery", "esri/geometry/webMercatorUtils",
"esri/geometry/scaleUtils", "esri/dijit/OverviewMap",
"esri/dijit/Scalebar", "esri/dijit/HomeButton",
"esri/dijit/Popup", "esri/dijit/PopupTemplate", "esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer",
"esri/symbols/SimpleMarkerSymbol", "esri/tasks/GeometryService",
"dojo/dom", "dojo/dom-construct", "dojo/parser", "dojo/_base/array",
"dijit/form/HorizontalSlider", "dijit/form/Button",
"dijit/form/DropDownButton",
"dijit/form/TextBox",
"dijit/form/CheckBox",
"dijit/Menu",
"dijit/MenuItem",
"esri/Color",
"dijit/layout/AccordionContainer",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dojo/domReady!"
function (
esriConfig, Map, utils, Extent, SpatialReference,
InfoTemplate, Legend,
LegendLayer, on, registry, BasemapGallery, webMercatorUtils,
scaleUtils, OverviewMap,
Scalebar, HomeButton,
Popup, PopupTemplate, ArcGISTiledMapServiceLayer,
ArcGISDynamicMapServiceLayer, FeatureLayer,
SimpleMarkerSymbol, GeometryService,
dom, domConstruct, parser, arrayUtils,
HorizontalSlider, Button, DropDownButton, TextBox, CheckBox, Menu, MenuItem, Color,
AccordionContainer, BorderContainer, ContentPane, TitlePane
parser.parse();
/* Define the initial extent for the map area */
//var initialExtent = new Extent({ "xmin": -12972052.788, "ymin": 5429282.436, "xmax": -11508904.02, "ymax": 6363263.470, "spatialReference": { "wkid": 3857 } });
// var llExtent = new Extent(-12972052.788, 5429282.436, -11508904.02, 6363263.470, new SpatialReference({ "wkid": 3857 }));
var legendLayers = [];
var popupOptions = {
markerSymbol: new SimpleMarkerSymbol("circle", 32, null,
new Color([0, 0, 0, 0.25])),
marginLeft: "20",
marginTop: "20"
var popup = new Popup(popupOptions, domConstruct.create("div"));
var map = new esri.Map("map", {
//extent: initialExtent,
basemap: "topo",
center: [-110, 47],
zoom: 6
//map.setExtent(llExtent);
/* Add the BASEMAP GALLERY from ESRI */
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
//basemapGallery.startup(); // This is commented out since handled in DDLB
/* Home Button */
var home = new HomeButton({
map: map
}, "HomeButton");
home.startup();
/* Scale Bar */
var scalebar = new Scalebar({
map: map,
/* Overview Map */
var overviewMapDijit = new OverviewMap({
map: map,
attachTo: "top-right",
height: 100,
width: 100,
visible: true
overviewMapDijit.startup();
map.on("load", function () { dojo.byId("mapName").innerHTML = "<strong>Current Basemap:</strong> Topographic"; });
/* When the map is loaded enable coordinate display in DIV */
map.on("mouse-move", showCoordinates);
map.on("mouse-drag", showCoordinates);
/* When the extent changes show the changed scale in DIV */
map.on("extent-change", changeScale);
/* When the extent changes show the new extent in DIV */
//map.on("extent-change", showExtent);
/* When the slider changes, change the opacity */
on(registry.byId("sliderOpacity"), "change", changeOpacity);
/* Create the DDLB for the basemaps layers and place
it in the DIV labeled "basemapMenu" in the Layers
section */
on(basemapGallery, "load", function () {
dojo.forEach(basemapGallery.basemaps, function (basemap) {
//Add a menu item for each basemap, when the menu items are selected
dijit.byId("basemapMenu").addChild(
new dijit.MenuItem({
label: basemap.title,
onClick: dojo.hitch(function () {
basemapGallery.select(basemap.id);
dojo.byId("mapName").innerHTML = "<strong>Current Basemap:</strong> " + basemap.title;
/* Create the legend */
map.on("layers-add-result", function () {
var legend = new Legend({
map: map,
layerInfos: legendLayers
}, "legendDiv");
legend.startup();
1:500,000 MBMG GEOLOGY LAYER DEFINITIONS
/* Add the MBMG 1:500,000 geology layer as a Tiled Map Service Layer */
var geo500Layer = new ArcGISTiledMapServiceLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Geology/Geology_500k/MapServer", { id: 'geo500Layer', opacity: 0.2 });
// map.addLayer(geo500Layer);
STREAMS LAYER DEFINITIONS
/* Add the STREAMS layer */
var streamLayer = new ArcGISDynamicMapServiceLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Surface/Streams/MapServer", { id: 'streamLayer' });
//map.addLayer(streamLayer);
legendLayers.push({
layer: streamLayer,
title: "Streams"
HYDROLOGIC UNIT CODE LAYER DEFINITIONS
/* Add the HUC layer */
var hucLayer = new ArcGISDynamicMapServiceLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Surface/HUCs/MapServer", { id: 'hucLayer' });
legendLayers.push({
layer: hucLayer,
title: "HUC Boundary"
//map.addLayer(hucLayer);
GWAAMON LAYER DEFINITIONS
Create a PopupTemplate for the GWAAMON layer - Superceded
by the InfoTemplate definition below
var gwaamonTemplate = new PopupTemplate({
title: "GWAAMON Site Details",
fieldInfos: [
{ fieldName: "gwicid", visible: true, label: "GWIC Id" },
{ fieldName: "site_name", visible: true, label: "Site Name" },
{ fieldName: "site_type", visible: true, label: "Site Type" },
{ fieldName: "township", visible: true, label: "Township" },
{ fieldName: "range", visible: true, label: "Range" },
{ fieldName: "section", visible: true, label: "Section" },
{ fieldName: "qsection", visible: true, label: "Q Section" },
{ fieldName: "swl_meas", visible: true, label: "# Meas" },
{ fieldName: "samples", visible: true, label: "W Qual" },
{ fieldName: "field_visits", visible: true, label: "F Visit" }
showAttachments: true
/* Create a new InfoTemplate for the GWAAMON layer 2014-12-29 */
var gwaamonInfoTemplate = new InfoTemplate();
gwaamonInfoTemplate.setTitle("GWIC Record ${gwicid}");
gwaamonInfoTemplate.setContent("<table>" +
"<tr valign='top'><td style='white-space:nowrap;'>Site Name</td><td>${site_name}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Well Log</td><td><a target='_newwellwin' href='http://mbmggwic.mtech.edu/sqlserver/v11/reports/SiteSummary.asp?gwicid=${gwicid}&agency=mbmg&reqby=M&'>View</a></td></tr>" +
"<tr><td style='white-space:nowrap;'>Site Type</td><td style='white-space:nowrap;'>${site_type}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Location</td><td style='white-space:nowrap;'>${township} ${range} ${section} ${qsection}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Water Levels</td><td>${swl_meas} <a target='_newwellwin' href='http://mbmggwic.mtech.edu/sqlserver/v11/reports/WellHydrograph.asp?gwicid=${gwicid}&agency=mbmg&reqby=M&'>Graph</a></td></tr>" +
"<tr><td style='white-space:nowrap;'>Samples</td><td>${samples}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Field Visits</td><td>${field_visits}</td></tr>" +
"</table>");
var gwaamonFeatureLayer = new FeatureLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Water/GWAAMON_wells/MapServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["gwicid", "site_name", "site_type", "township", "range", "section", "qsection", "swl_meas", "samples", "field_visits"],
infoTemplate: gwaamonInfoTemplate
legendLayers.push({
layer: gwaamonFeatureLayer,
title: "MBMG GWAAMON Network"
//map.addLayer(gwaamonFeatureLayer);
GWIC LAYER DEFINITIONS
/* Create a new InfoTemplate for the MBMG SWAMP layer 2014-12-29 */
var gwicInfoTemplate = new InfoTemplate();
gwicInfoTemplate.setTitle("GWIC Record ${GWICId}");
gwicInfoTemplate.setContent("<table>" +
"<tr><td style='white-space:nowrap;'>Total Depth</td><td>${total_depth}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Static Water Level</td><td>${swl}</td></tr>" +
"</table>");
var gwicFeatureLayer = new FeatureLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Water/GWIC_wells_map_service_250k_vis/MapServer/0",
infoTemplate: gwicInfoTemplate,
outFields: ["*"]
legendLayers.push({
layer: gwicFeatureLayer,
title: "GWIC Wells"
/* Add the layers to the map that have been defined above */
map.addLayers([geo500Layer, streamLayer, hucLayer, gwaamonFeatureLayer, gwicFeatureLayer]);
/* Turn on mouse features */
// map.enableScrollWheelZoom();
//map.enableDoubleClickZoom();
Build the check boxes that represent the layers
that have been added to the map above.
//add check boxes
arrayUtils.forEach(legendLayers, function (layer) {
var layerName = layer.title;
var checkBox = new CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible
checkBox.on("change", function () {
var targetLayer = map.getLayer(this.value);
targetLayer.setVisibility(!targetLayer.visible);
this.checked = targetLayer.visible;
//add the check box and label to the toc
domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");
var checkLabel = domConstruct.create("label", {
"for": checkBox.name,
innerHTML: layerName
}, checkBox.domNode, "after");
domConstruct.place("<br />", checkLabel, "after");
/* Re-size the infoWindow to fit the standard contents */
map.infoWindow.resize(300, 150);
/* Function to change the opacity of a layer */
function changeOpacity(op) {
var newOp = (op / 100);
geo500Layer.setOpacity(newOp);
/* Show Lat/Long coordinate pairs */
function showCoordinates(evt) {
var mp = webMercatorUtils.webMercatorToGeographic(evt.mapPoint);
dom.byId("currentPosition").innerHTML = "<strong>Lon:</strong> " + mp.x.toFixed(6) + "<strong> Lat:</strong> " + mp.y.toFixed(6) + " ";
/* New changeScale function uses esri/geometry/scaleUtils */
function changeScale() {
var scale = scaleUtils.getScale(map);
dojo.byId("currentScale").innerHTML = "<strong>Scale:</strong> 1:" + addCommas(scale.toFixed(0));
/* Custom function to add commas to a string (number) */
function addCommas(inVal) {
inVal += '';
x = inVal.split('.');
x1 = x[0];
x2 = x.length > 1 ? '.' + x[1] : '';
var rgx = /(\d+)(\d{3})/;
while (rgx.test(x1)) {
x1 = x1.replace(rgx, '$1' + ',' + '$2');
return x1 + x2;
/* Extents */
function showExtent() {
var s = "";
s = "XMin: " + map.extent.xmin + "<br/>"
+ " YMin: " + map.extent.ymin + "<br/>"
+ " XMax: " + map.extent.xmax + "<br/>"
+ " YMax: " + map.extent.ymax;
dojo.byId("extentDisplay").innerHTML = s;
and the html is
<!DOCTYPE html>
<!--[if lt IE 7]> <html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default ie6"> <![endif]-->
<!--[if IE 7]> <html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default ie7"> <![endif]-->
<!--[if IE 8]> <html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default ie8"> <![endif]-->
<!--[if gt IE 8]><!-->
<html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default" lang="en">
<!--<![endif]-->
<head>
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no">
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">
<title>Getting Started - Mobile</title>
<meta name="description" content="MBMG">
<meta name="keywords" content="Montana Bureau of Mines and Geology">
<meta name="poweredby" content="finalsite.com">
<meta http-equiv="X-UA-Compatible" content="IE=Edge">
<meta http-equiv="Expires" content="0">
<meta http-equiv="Content-Type" content="text/html;charset=iso-8859-1">
<script type="text/javascript">window.NREUM || (NREUM = {}), __nr_require = function (t, e, n) { function r(n) { if (!e) { var o = e = { exports: {} }; t[0].call(o.exports, function (e) { var o = t[1]; return r(o || e) }, o, o.exports) } return e.exports } if ("function" == typeof __nr_require) return __nr_require; for (var o = 0; o < n.length; o++) r(n); return r }({ 1: [function (t, e, n) { function r() { } function o(t, e, n) { return function () { return i(t, [(new Date).getTime()].concat(u(arguments)), e ? null : this, n), e ? void 0 : this } } var i = t("handle"), a = t(2), u = t(3), c = t("ee").get("tracer"), f = NREUM; "undefined" == typeof window.newrelic && (newrelic = f); var s = ["setPageViewName", "setCustomAttribute", "finished", "addToTrace", "inlineHit"], p = "api-", l = p + "ixn-"; a(s, function (t, e) { f = o(p + e, !0, "api") }), f.addPageAction = o(p + "addPageAction", !0), e.exports = newrelic, f.interaction = function () { return (new r).get() }; var d = r.prototype = { createTracer: function (t, e) { var n = {}, r = this, o = "function" == typeof e; return i(l + "tracer", [Date.now(), t, n], r), function () { if (c.emit((o ? "" : "no-") + "fn-start", [Date.now(), r, o], n), o) try { return e.apply(this, arguments) } finally { c.emit("fn-end", [Date.now()], n) } } } }; a("setName,setAttribute,save,ignore,onEnd,getContext,end,get".split(","), function (t, e) { d = o(l + e) }), newrelic.noticeError = function (t) { "string" == typeof t && (t = new Error(t)), i("err", [t, (new Date).getTime()]) } }, {}], 2: [function (t, e, n) { function r(t, e) { var n = [], r = "", i = 0; for (r in t) o.call(t, r) && (n = e(r, t), i += 1); return n } var o = Object.prototype.hasOwnProperty; e.exports = r }, {}], 3: [function (t, e, n) { function r(t, e, n) { e || (e = 0), "undefined" == typeof n && (n = t ? t.length : 0); for (var r = -1, o = n - e || 0, i = Array(o < 0 ? 0 : o) ; ++r < o;) i = t[e + r]; return i } e.exports = r }, {}], ee: [function (t, e, n) { function r() { } function o(t) { function e(t) { return t && t instanceof r ? t : t ? u(t, a, i) : i() } function n(n, r, o) { t && t(n, r, o); for (var i = e(o), a = l(n), u = a.length, c = 0; c < u; c++) a.apply(i, r); var s = f[m]; return s && s.push([w, n, r, i]), i } function p(t, e) { g = l(t).concat(e) } function l(t) { return g || [] } function d(t) { return s = s || o(n) } function v(t, e) { c(t, function (t, n) { e = e || "feature", m = e, e in f || (f = []) }) } var g = {}, m = {}, w = { on: p, emit: n, get: d, listeners: l, context: e, buffer: v }; return w } function i() { return new r } var a = "nr@context", u = t("gos"), c = t(2), f = {}, s = {}, p = e.exports = o(); p.backlog = f }, {}], gos: [function (t, e, n) { function r(t, e, n) { if (o.call(t, e)) return t; var r = n(); if (Object.defineProperty && Object.keys) try { return Object.defineProperty(t, e, { value: r, writable: !0, enumerable: !1 }), r } catch (i) { } return t = r, r } var o = Object.prototype.hasOwnProperty; e.exports = r }, {}], handle: [function (t, e, n) { function r(t, e, n, r) { o.buffer(, r), o.emit(t, e, n) } var o = t("ee").get("handle"); e.exports = r, r.ee = o }, {}], id: [function (t, e, n) { function r(t) { var e = typeof t; return !t || "object" !== e && "function" !== e ? -1 : t === window ? 0 : a(t, i, function () { return o++ }) } var o = 1, i = "nr@id", a = t("gos"); e.exports = r }, {}], loader: [function (t, e, n) { function r() { if (!h++) { var t = y.info = NREUM.info, e = s.getElementsByTagName("script")[0]; if (t && t.licenseKey && t.applicationID && e) { c(m, function (e, n) { t || (t = n) }); var n = "https" === g.split(":")[0] || t.sslForHttp; y.proto = n ? "https://" : "http://", u("mark", ["onload", a()], null, "api"); var r = s.createElement("script"); r.src = y.proto + t.agent, e.parentNode.insertBefore(r, e) } } } function o() { "complete" === s.readyState && i() } function i() { u("mark", ["domContent", a()], null, "api") } function a() { return (new Date).getTime() } var u = t("handle"), c = t(2), f = window, s = f.document, p = "addEventListener", l = "attachEvent", d = f.XMLHttpRequest, v = d && d.prototype; NREUM.o = { ST: setTimeout, CT: clearTimeout, XHR: d, REQ: f.Request, EV: f.Event, PR: f.Promise, MO: f.MutationObserver }, t(1); var g = "" + location, m = { beacon: "bam.nr-data.net", errorBeacon: "bam.nr-data.net", agent: "js-agent.newrelic.com/nr-963.min.js" }, w = d && v && v
&& !/CriOS/.test(navigator.userAgent), y = e.exports = { offset: a(), origin: g, features: {}, xhrWrappable: w }; s
? (s
("DOMContentLoaded", i, !1), f
("load", r, !1)) : (s("onreadystatechange", o), f("onload", r)), u("mark", ["firstbyte", a()], null, "api"); var h = 0 }, {}] }, {}, ["loader"]);</script>
<link rel="shortcut icon" href="http://mbmgweb.mtech.edu/newweb/favicon.ico">
<link rel="canonical" href="http://www.misericordia.edu/page.cfm?p=501">
<link rel="stylesheet" href="http://www.misericordia.edu/styles.cfm?b=1469446013869">
<link type="text/css" rel="stylesheet" href="http://mbmgweb.mtech.edu/newweb3/ss.css">
<style type="text/css">
body {
margin-top: 0px;
margin-right: 0;
margin-bottom: 0;
margin-left: 0px;
color: #;
font: 14px;
line-height: 150%;
table {
text-align: left;
a {
color: #;
a:visited {
color: #;
a:active {
color: #;
input {
font: 14px;
color: #;
select {
font: 14px;
textarea {
font: 14px;
color: #;
.buttons {
font: 14px;
color: white;
font-weight: bold;
background-color: #;
.text_misc, .text_misc td {
line-height: normal;
.text_misc p {
margin-top: 0px;
.hier {
font: 10px;
color: #;
#topbanner {
width: 100%;
margin-top: 0px;
margin-right: auto;
margin-left: auto;
padding-top: 0px;
padding-right: 0px;
padding-bottom: 0px;
padding-left: 0px;
#midcontainer {
#mainmiddle {
width: 100%;
min-height: 200px;
margin-top: 0px;
margin-right: auto;
margin-bottom: 0px;
margin-left: auto;
#contentdiv {
min-height: 200px;
height: 100%;
#bottomcontainer {
clear: both;
text-align: center;
#bottombanner {
width: 100%;
margin-top:;
margin-right: auto;
margin-bottom:;
margin-left: auto;
padding-top: 0px;
padding-right: 0;
padding-left: 0px;
#poweredby {
padding-top: 5px;
padding-bottom: 5px;
text-align: center;
#poweredby div {
width: 100%;
margin: auto;
</style>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/jQuery/jquery.min.js"></script>
<script type="text/javascript"> var $j = jQuery.noConflict(); </script>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/fs_global.js"></script>
window.name = 'finalsite_misericordia';
var pageid = 501;
var pagearray = new Array();
pagearray[0] = 501;
trackingpath = '/Academics'; //Fix syntax highlighting "
</script>
<style type="text/css" media="screen">
#navtable_5 {
list-style-type: none;
margin: 0px 0px 0px 0px;
padding: 0;
#navtable_5 ul {
margin: 0;
padding: 0;
#navtable_5 a, #navtable_5 a:link, #navtable_5 a:visited {
display: block;
padding-top: 0px;
padding-right: 0px;
padding-left: 0px;
margin-bottom: 0px;
font-size: 13px;
text-decoration: none;
#navtable_5 span {
display: block;
background-image: none !important;
/* 2nd level */
#navtable_5 ul a {
background: none !important;
padding-left: 24px !important;
border-color: transparent !important;
font-size: 13px !important;
font-weight: normal !important;
#navtable_5 ul a span {
/* 3rd level */
#navtable_5 ul ul a {
padding-left: 36px !important;
#navtable_5 ul ul a span {
/* On State */
#navtable_5 a.navon {
#navtable_5 a.navon span {
/* Hover State */
#navtable_5 a:hover {
</style>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/jQuery/plugins/jquery.fsBreakly.js"></script>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/pages/blogs/blog.js"></script>
<link rel="stylesheet" type="text/css" href="http://newcss.finalsite.com/160724/css/news/news.css">
<link type="text/css" rel="stylesheet" href="http://newjs.finalsite.com/160724/javascript/jQuery/themes/finalsite/jquery.ui.1.8rc3.css">
<style type="text/css"></style>
#bannermod208 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod208, #bannermod208 td {
#bannermod208 .bannermodtitle {
#bannermod208 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod180 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod180, #bannermod180 td {
#bannermod180 .bannermodtitle {
#bannermod180 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod10 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod10, #bannermod10 td {
#bannermod10 .bannermodtitle {
#bannermod10 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod334 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod334, #bannermod334 td {
#bannermod334 .bannermodtitle {
#bannermod334 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod182 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod182, #bannermod182 td {
#bannermod182 .bannermodtitle {
#bannermod182 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#leftbanner {
width: 208px;
#bannermod5 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod5, #bannermod5 td {
#bannermod5 .bannermodtitle {
#bannermod5 .bannermodtd {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#rightbanner {
width: 220px;
#bannermod262 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod262, #bannermod262 td {
#bannermod262 .bannermodtitle {
#bannermod262 .bannermodtd {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#rightbanner {
width: 220px;
#bannermod207 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod207, #bannermod207 td {
#bannermod207 .bannermodtitle {
#bannermod207 .bannermodtd {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod224 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod224, #bannermod224 td {
#bannermod224 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod224 .bannermodtitle {
#bannermod184 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod184, #bannermod184 td {
#bannermod184 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod184 .bannermodtitle {
#bannermod191 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod191, #bannermod191 td {
#bannermod191 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod191 .bannermodtitle {
#bannermod193 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod193, #bannermod193 td {
#bannermod193 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod193 .bannermodtitle {
#bannermod194 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod194, #bannermod194 td {
#bannermod194 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod194 .bannermodtitle {
#bannermod195 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod195, #bannermod195 td {
#bannermod195 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod195 .bannermodtitle {
#bannermod196 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod196, #bannermod196 td {
#bannermod196 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod196 .bannermodtitle {
#bannermod197 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod197, #bannermod197 td {
#bannermod197 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod197 .bannermodtitle {
#bannermod192 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod192, #bannermod192 td {
#bannermod192 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod192 .bannermodtitle {
#bannermod185 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod185, #bannermod185 td {
#bannermod185 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod185 .bannermodtitle {
</style>
<!-- BROWSER VIEWPORT -->
<meta name="viewport" content="initial-scale=1, width=device-width" />
<!-- CORE STYLESHEETS -->
<link href="http://mbmgweb.mtech.edu/newweb3/core.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/layout.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/core-desktop.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/core-tablet.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/core-mobile.css" rel="stylesheet" type="text/css">
<!-- CUSTOM STYLESHEET -->
<link href="http://mbmgweb.mtech.edu/newweb3/custom.css?604" rel="stylesheet" type="text/css">
<link href="http://www.misericordia.edu/uploaded/code/revisions.css?527" rel="stylesheet" type="text/css">
<!-- LIBRARY CSS -->
<link href="http://maxcdn.bootstrapcdn.com/font-awesome/4.2.0/css/font-awesome.min.css" rel="stylesheet">
<link rel="stylesheet" href="http://www.misericordia.edu/uploaded/template/code/jquery.mCustomScrollbar.css" />
<!-- IE RELATED FIXES -->
<!--[if lte IE 8]>
<link href="uploaded/template/code/ie-fix.css" rel="stylesheet">
<link href="uploaded/template/code/ie-news.css" rel="stylesheet">
<script src="uploaded/code/css3-mediaqueries.js" type="text/javascript" language="javascript"></script>
<![endif]-->
<!-- JQUERY PLUGINS & SNIPPETS -->
<script src="http://www.misericordia.edu/uploaded/code/jquery.flexslider.js"></script>
<script src="http://malihu.github.io/custom-scrollbar/jquery.mCustomScrollbar.concat.min.js"></script>
<!-- LOCALIZED SCRIPTS -->
<script src="http://www.misericordia.edu/uploaded/template/code/jquery.core.js?v=2"></script>
<!-- INSERT TYPEKITS OR GOOGLE FONTS -->
<link href='http://fonts.googleapis.com/css?family=Source+Sans+Pro:400,600,700,700italic,600italic,400italic,300...' rel='stylesheet' type='text/css'>
<script>
(function (i, s, o, g, r, a, m) {
i['GoogleAnalyticsObject'] = r; i = i || function () {
(i.q = i.q || []).push(arguments)
}, i.l = 1 * new Date(); a = s.createElement(o),
m = s.getElementsByTagName(o)[0]; a.async = 1; a.src = g; m.parentNode.insertBefore(a, m)
})(window, document, 'script', '//www.google-analytics.com/analytics.js', 'ga');
ga('create', 'UA-3000352-1', 'auto');
ga('send', 'pageview');
</script>
<!-- Start of Async HubSpot Analytics Code -->
(function (d, s, i, r) {
if (d.getElementById(i)) { return; }
var n = d.createElement(s), e = d.getElementsByTagName(s)[0];
n.id = i; n.src = '//js.hs-analytics.net/analytics/' + (Math.ceil(new Date() / r) * r) + '/536549.js';
e.parentNode.insertBefore(n, e);
})(document, "script", "hs-analytics", 300000);
</script>
<!-- End of Async HubSpot Analytics Code -->
<!-- Go to www.addthis.com/dashboard to customize your tools -->
<script type="text/javascript" src="//s7.addthis.com/js/300/addthis_widget.js#pubid=ra-54be8237215169f8" async="async"></script>
<!-- begin CBE code -->
<script>
(function (a, b, c, d, e, f, g) {
a = a || function () { (a.q = a.q || []).push(arguments) }; f = b.createElement(c);
g = b.getElementsByTagName(c)[0]; f.async = 1; f.src = d + "/cbe/"; g.parentNode.insertBefore(f, g);
a('create', d, 2);
a('log', 'pageview');
})(window, document, "script", "https://mis.capturehighered.net", "_cbe");
</script>
<!-- end CBE code -->
<!-- Siteimprove code -->
<script>
(function () {
var sz = document.createElement('script'); sz.type = 'text/javascript'; sz.async = true;
sz.src = '//us1.siteimprove.com/js/siteanalyze_54160.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(sz, s);
</script>
<!-- End of Siteimprove code -->
<!-- Support -->
<link href="http://mbmgweb.mtech.edu/newweb3/support.custom.css?542016" rel="stylesheet" type="text/css">
<script src="http://www.misericordia.edu/uploaded/themes/library/js/support.custom.js"></script>
<!-- Bootstrap core CSS
<link href="http://mbmgweb.mtech.edu/newweb3/bootstrap.min.css" rel="stylesheet">-->
<!-- IE10 viewport hack for Surface/desktop Windows 8 bug -->
<link href="https://getbootstrap.com/assets/css/ie10-viewport-bug-workaround.css" rel="stylesheet">
<!-- Custom styles for this template -->
<link href="http://mbmgweb.mtech.edu/newweb3/signin.css" rel="stylesheet">
<!-- Just for debugging purposes. Don't actually copy these 2 lines! -->
<!--[if lt IE 9]><script src="../../assets/js/ie8-responsive-file-warning.js"></script><![endif]-->
<script src="https://getbootstrap.com/assets/js/ie-emulation-modes-warning.js"></script>
<!-- HTML5 shim and Respond.js for IE8 support of HTML5 elements and media queries -->
<!--[if lt IE 9]>
<script src="https://oss.maxcdn.com/html5shiv/3.7.3/html5shiv.min.js"></script>
<script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
<![endif]-->
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18esri/css/esri.css" />
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="http://data.mbmg.mtech.edu/css/mapperStyles_1.css">
<script type="text/javascript" src="http://js.arcgis.com/3.13/"></script>
<script type="text/javascript" src="http://mbmgweb.mtech.edu/3.13/mapper/js/productionQuakesView313.js"></script>
<link rel="stylesheet" href="https://developers.arcgis.com/javascript/3/samples/mobile_template/css/main.css">
#HomeButton {
position: absolute;
top: 95px;
left: 20px;
z-index: 50;
</style>
</head>
<body class="yui-skin-sam" onload="try{pageLoad()}catch(err){};try{loadmap()}catch(err){}">
<div id="bodydiv" class="text">
<!-- Start Top Banner -->
<div id="topcontainer">
<div id="topbanner">
<div id="bannermod208" class="top-nav-slide mobile">
<div id="bannerdiv208" class="bannermodcontent">
<div style="clear: both;"><!-- --></div>
<div id="content208">
<button type="button" id="mobile-nav-close">Close</button>
<form method="get" action="searchresults.cfm" name="fs_search">
<input name="keywords" placeholder="search mbmg" id="search_keywords" type="text">
<label for="search_keywords">Search Keywords</label>
<button type="submit" id="search_submit"><i class="fa fa-search"></i>Search</button>
</form>
<ul class="nav-m-main"></ul>
<ul class="nav-m-quick"></ul>
</div>
</div>
</div>
<div id="bannermod180" class="header-logo row">
<div id="bannerdiv180" class="bannermodcontent">
<div id="content180">
<!-- LOGO -->
<a href="page.cfm?p=1" class="site-logo"><img src="http://mbmgweb.mtech.edu/newweb3/logombmg.png" alt="Clicking the Misericordia University logo will return you to the homepage"></a>
<!-- END LOGO -->
<!-- SEARCH BAR -->
<input name="keywords" id="search_keywords_mobile" placeholder="search mbmg" type="text">
<label for="search_keywords_mobile">Search Keywords</label>
</form>
<!-- END SEARCH -->
<!-- HEADER NAV -->
<ul>
<li><a href="#">Home</a></li>
<li><a href="#">Well Data</a></li>
<li><a href="#">Reports</a></li>
<li><a href="#">DrillerWeb</a></li>
<li><a href="#">DNRC</a></li>
<li><a href="#">Help!</a></li>
</ul>
<!-- END HEADER NAV -->
<!-- MOBILE NAV TRIGGER -->
<button id="mobile-nav-control" class="mobile" type="button"><i class="fa fa-navicon"></i> Menu</button>
<!-- END MOBILE NAV TRIGGER -->
</div>
</div>
</div>
<div id="bannermod10" class="main-nav">
<div id="bannerdiv10" class="bannermodcontent">
<div id="content10">
<ul id="nav" class="row">
<li><a href="https://community.esri.com/Final_v1/main.html" target="_self" class="fsBtn">Home</a></li>
<li><a href="https://community.esri.com/Final_v1/about/about-mbmg.html?p=499" target="_self" class="fsBtn">About</a></li>
<li><a href="../newweb3/page.cfm?p=503" class="fsBtn">Research</a></li>
<li><a href="../newweb3/page.cfm?p=505" class="fsBtn">Information</a></li>
<li><a href="https://community.esri.com/Final_v1/museum/museum-main.html?p=504" target="_self" class="fsBtn">Mineral Museum</a></li>
<li><a href="../newweb3/njf/page.cfm?p=506" class="fsBtn">Kids</a></li>
</ul>
</div>
</div>
</div>
</div>
</div>
<div id="bannermod334" class="print-page">
<div id="bannerdiv334" class="bannermodcontent">
<!-- <div id="content334"><span id="print-page"><a href="#" title="print page" onclick="printpage(); return false;"><img src="http://www.misericordia.edu/images/admin_ui/2.0/black/print.png" alt="print calendar" border="0"></a></span></div>-->
</div>
</div>
<!--<div id="bannermod182" class="hier-tools hidden">
<div id="bannerdiv182" class="bannermodcontent">
<div style="clear: both;"></div>
<div id="content182">
<div class="hiersect"><a href="page.cfm?p=1">Home</a> > <div class=hier style='margin-left: 0'>Information</div>
</div>
</div>
</div>-->
</div><!-- end topbanner-->
</div><!-- End topcontainer -->
<!-- Begin middle section -->
<div id="midcontainer">
<div id="mapView" data-dojo-type="dojox.mobile.View" data-dojo-props="selected: true">
<div id="mapContainer" data-dojo-type="dojox.mobile.ContentPane">
<div id="map"></div>
</div>
</div>
</div>
<!-- end of midcontainer -->
<!-- begin bottombanner-->
<!-- end bottombanner -->
<!-- end bottomcontainer -->
</div> <!-- end of body -->
<div id="nav_menus" style="position:absolute; top:0; left:0;">
<div id="dhtmlmenu_499" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_499',this.id);">
<ul>
<li>
<a href="page.cfm?p=518">Staff Information</a>
</li>
<li>
<a href="page.cfm?p=565">Location</a>
</li>
<li>
<a href="page.cfm?p=516">Director's Message</a>
</li>
<li>
<a href="page.cfm?p=515">Current Jobs</a>
</li>
</ul>
</div>
<div id="dhtmlmenu_500" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_500',this.id);">
<ul>
<li>
<a href="http://misericordia.edu/page.cfm?p=986" target="_blank">MU Today</a>
</li>
<li>
<a href="http://www.misericordia.edu/page.cfm?p=779" target="_blank">Publications</a>
</li>
<li>
<a href="page.cfm?p=520">Campus Calendar</a>
</li>
</ul>
</div>
<div id="dhtmlmenu_501" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_501',this.id);">
<ul>
<li>
<a href="http://misericordia.edu/page.cfm?p=540" target="_blank">Apply Now</a>
</li>
<li>
<a href="page.cfm?p=530">Majors and Programs</a>
</li>
<li>
<a href="page.cfm?p=709">Academic Colleges</a>
</li>
<li>
<a href="page.cfm?p=710">University Catalog</a>
</li>
<li>
<a href="page.cfm?p=524">Course Schedule</a>
</li>
<li>
<a href="page.cfm?p=712">Honors Program</a>
</li>
<li>
<a href="page.cfm?p=713">Vice President of Academic Affairs</a>
</li>
<li>
<a href="page.cfm?p=714">Office of Service-Learning</a>
</li>
<li>
<a href="page.cfm?p=523">Registrar</a>
</li>
<li>
<a href="page.cfm?p=1476">Academic Calendars</a>
</li>
<li>
<a href="http://library.misericordia.edu">Library</a>
</li>
<li>
<a href="page.cfm?p=1371">Commencement</a>
</li>
<li>
<a href="http://studyabroad-away.misericordia.edu/">Study Abroad/Study Away</a>
</li>
</ul>
</div>
</div>-->
<div id="dhtmlmenu_503" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_503',this.id);">
<ul>
<li>
<a href="http://athletics.misericordia.edu/" target="_blank">GWIC</a>
</li>
<li>
<a href="http://athletics.misericordia.edu/staff.aspx" target="_blank">SWAMP</a>
</li>
<li>
<a href="http://athletics.misericordia.edu/hof.aspx?type=class_induction#" target="_blank">GWIP</a>
</li>
<li>
<a href="http://athletics.misericordia.edu/sports/2012/9/17/AthFac_0917120421.aspx" target="_blank">GWAP</a>
</li>
</ul>
</div>
<div id="dhtmlmenu_505" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_503',this.id);">
<ul>
<li>
<a href="http://athletics.misericordia.edu/" target="_blank">Mining Program</a>
</li>
<li>
<a href="http://www.mucougarsgear.com/" target="_blank">Geologic Research and Mapping</a>
</li>
<li>
<a href="http://www.mucougarsgear.com/" target="_blank">State Geology Map</a>
</li>
<li>
<a href="http://www.mucougarsgear.com/" target="_blank">GIS</a>
</li>
</ul>
</div>
<!-- <div id="dhtmlmenu_504" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_504',this.id);">
</div>-->
<div id="dhtmlmenu_506" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_506',this.id);">
<ul>
<li>
<a href="http://cougarconnect.misericordia.edu/s/352/index.aspx?sid=352&gid=1&pgid=938" target="_blank">Science fair</a>
</li>
</ul>
</div>
<!-- Quick Links Setup -->
<div id="ql_menu" onmouseover="fsBtn('ql_btn');" onmouseout="fsBtn('ql_btn','off');" style="visibility: hidden;">
<ul><li><a href="https://mymu.misericordia.edu" target="_blank">Home</a></li><li><a href="https://mymu.misericordia.edu" target="_blank">WellData</a></li><li><a href="http://cougarconnect.misericordia.edu" target="_blank">Reports</a></li><li><a href="page.cfm?p=557" target="_self">DrillerWeb</a></li><li><a href="page.cfm?p=557" target="_self">DrillerWeb</a></li><li><a href="page.cfm?p=557" target="_self">DNRC</a></li></ul>
</div>
<!-- End Quick Links Setup -->
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/jQuery/jquery.ui.min.js"></script>
var relativeBasePath = '';
var siteurl = 'http://www.misericordia.edu';
var siteSSLurl = 'https://www.misericordia.edu';
var baseurl = '';
</script>
<script type="text/javascript">window.NREUM || (NREUM = {}); NREUM.info = { "errorBeacon": "bam.nr-data.net", "licenseKey": "17f1641df3", "agent": "", "beacon": "bam.nr-data.net", "applicationTime": 510, "applicationID": "3347190,3347007,1110036", "transactionName": "b1wDZ0dSXBUFBRZZC1YWIkZGR10LSxYDVwEWWgdeGkBGBwoCA0IA", "queueTime": 0 }</script>
</body>
</html>
