I have been trying to get the Create 3D Flood Level from Raster tool in the Flood Impact Analysis Solution to run for several weeks now. Each time I try to run it, I get the following error. I have tried various names for the output feature, saving it to a geodatabase versus a folder, and nothing will get it to run correctly. It will either fail after a few minutes, or after 2.5 hours. Is there a fix for this?
Duplicate... please don't repost
Hi Amanda,
I tested with your data and it seems releated to using the 'memory' workspace. There are a couple of things you can do:
