Pre-Incident Planning Solution
187
03-27-2024 06:50 AM
GaryMorris
New Contributor III
I am working on setting up the Pre-Incident Planning Solution; I want to have the feature layers in our SDE.  For the most part the transition has been smooth.  I am having trouble with one part.
The Dashboard has two data expressions.  I thought I could just replace the Portal Name and the ID and it would work, since the fields that are being called in the expression exits in the SDE published Feature Class.  Any help would be greatly appreciated.
JeremiahLindemann
It is recommended to use the layers that come with the solution to ensure everything works properly:
https://doc.arcgis.com/en/arcgis-solutions/latest/get-started/faqs.htm#anchor7
For example, there may be additional settings on the gdb that are added causing this such as attribute rules that aren't supported with some Arcade functions?
https://community.esri.com/t5/attribute-rules-questions/arcade-error-featuresetbyportalitem-cannot-b...
GaryMorris
New Contributor III
Thank you for the response, Jeremiah; to give some more information on my situation.  I loaded my data into the ESRI feature layers and then added them to my SDE.  I published them from the SDE and I am just replacing the layers.  I did add a few fields but I did not add any attribute rules.
