Adding a field to a raster with values from another raster
284
02-04-2024 10:26 PM
BlairPellegrino
New Contributor III
I have two rasters - one with temperature values and another with values from 0-255 which will be used to represent a stretch colour ramp for the same data.
Essentially I need these to be combined into a single raster, with the 'VALUE' field representing the stretch colour ramp and an additional 'TEMPERATURE' field with the corresponding temperature value at each location.  This will allow me to use the 'VALUE' field to symbolise the data and the 'TEMPERATURE' field in the popup to show the temperature at that location (ultimately within a web map).
It seems simple enough, but I have played around with the Combine tool and Sample tool and can't seem to find a solution that gets me quite what I need.
Any ideas?
NB I'm ultimately needing to do this for x5 different areas which will be mosaiced together, using the 0-255 stretch values to ensure more consistent symbology across the x5 different areas.
