SO basically my problem is that every time I run the euclidean distance tool on a piece of data (they are all polygons) the display returns the same value no matter what data I run it on. Also in the picture I uploaded you can see that the display is not Geo-referenced even though I manually Geo-referenced the data I used with the DEM. Any help as to what I did wrong would be much Appreciated. Thank you.
Do the polygon feature class and the gird share the same coordinate system, datum, and projection? As a general rule any tool that uses both raster and vector data need the same coordinate system, datum, and projection.
