Contour tool - empty attribute table
2700
8
10-09-2014 01:00 AM
CamillaSanticoli1
New Contributor II
Hi all! I am trying to create contour lines from a DEM. When I execute the function with the spatial analyst tool it says that it has done it correctly but no contours are displayed and if I try to open the table of attribute it's empty. What could be the problem?
Thank you:)
DanPatterson_Retired
bizzare...copy the raster to a simple folder  c:/test/myraster, start a new project, add the raster, run the contour specifying the destination folder the same as the aforementioned, call it X just so you rule out any filenaming issues.
Option 2, try to contour a different raster
DallasShearer
check your parameters, if your start contour level is not within the range of the DEM values and your interval to draw the contours from the start point also miss the values that fall in the range of the DEM then you would end up with an empty dataset.
CamillaSanticoli1
New Contributor II
Thank you for the reply!Actually I am not defining any initial contour level, I am only defining the distance at which I want my contours. My DEM is going from 1414 m to 2674 m. How can check if the interval of contours fall within the exact range? Thank you
right-click on the raster, select Properties, then examine within there the min and max...alternately, you can find out the min and max from the symbology.  if there is no data range listed, or it is outside the desired range, then something may be wrong with the raster.  This of course assumes that the raster you are trying to contour has X, Y and Z in the same units which should be meters (or sometimes in feet in the case of the U.S)
CamillaSanticoli1
New Contributor II
the raster has a minimum of 979 m and a maximum of 2751 m...which is reasonable. I can see the table of attribute of my raster but then I cannot see anything if I try to compute the contours. I tried everthing but I don't know what's wrong.
Thanks
CamillaSanticoli1
New Contributor II
Thank you very much. I just figure out that with another raster it creates contour without problem so maybe it's just that one that has something wrong, but at least the tool works properly!
Also, have a good read through Contour Spatial Analyst  help section...there a lot of caveats.  An try running the tool without a base contour specified...it is optional...and let SA do the work
CamillaSanticoli1
New Contributor II
I never set the base contour. But it hasn't worked anyway!
