Due to poor python skills i don't have the possibility to write scripts to automate my raster operations. As a solution to my problems I thought the batch mode of raster calculator would do the trick. I use Microsoft Excel to generate commands and pathways for the output files, resulting in long lists. But much to my dismay I can't find any way to enter them all at the same time in the batch window. I have been forced to copy every single line by it self, and paste in to each corresponding batch row.
I guess there must be a way to paste them in a more efficient way, but I can't find out how. If somebody could suggest me a solution I would be forever grateful!
from arcpy.sa import *
In Arc 10.x, you should be able to paste your raster calculator expressions into the python command window, as long as you enter this line first:from arcpy.sa import *
That's terrific! Thank you alot! Do you know how to specify output location/filename in this way? Right now it exports to a standard folder with some generic name.
I have used concatenate function in excel to prepare the list of the calculator expressions [not sure if it is in the true format] and their output directories and file names as below."J:\sp1\sp1_Thresholded_0_3.img" + "J:\sp1\sp1_A2a_2020_Thresholded.img" ==> "J:\sp1\sp1_CCCMA_A2a_2020_GainLoss.img"
from arcpy.sa import * rst = r"J:\sp1\sp1_Thresholded_0_3.img" + r"J:\sp1\sp1_A2a_2020_Thresholded.img";rst.save(r"J:\sp1\sp1_CCCMA_A2a_2020_GainLoss.img")
