Difficulty in executing code in Raster Calculator
1649
09-09-2016 11:14 AM
PolashBanerjee
New Contributor II
Hi
I am tring to execute an expression in Raster Calculator. It's rather a long piece of code:
Con("LULCyear2005_2006_500m_Raster" == 1 & "soilRaster_reclass" == 1 & "slope_reclass" == 1, 0.5, Con("LULCyear2005_2006_500m_Raster" == 1 & "soilRaster_reclass" == 1 & "slope_reclass" == 2, 0.55, Con("LULCyear2005_2006_500m_Raster" == 1 & "soilRaster_reclass" == 1 & "slope_reclass" == 3, 0.6, Con("LULCyear2005_2006_500m_Raster" ==28 &  "soilRaster_reclass" == 1 & "slope_reclass" == 1, 0.4,  Con("LULCyear2005_2006_500m_Raster" == 28 & "soilRaster_reclass" == 1 & "slope_reclass" == 2, 0.7, Con("LULCyear2005_2006_500m_Raster" == 28 & "soilRaster_reclass" == 1 & "slope_reclass" == 3, 0.82, Con("LULCyear2005_2006_500m_Raster" == 28 & "soilRaster_reclass" == 2 & "slope_reclass" == 1, 0.3, Con("LULCyear2005_2006_500m_Raster" == 28 & "soilRaster_reclass" == 2 & "slope_reclass" == 2, 0.4, Con("LULCyear2005_2006_500m_Raster" == 28 & "soilRaster_reclass" == 2 & "slope_reclass" == 3, 0.52, Con("LULCyear2005_2006_500m_Raster" == 71, 0.33, Con("LULCyear2005_2006_500m_Raster" == 77 & "soilRaster_reclass" == 1 & "slope_reclass" == 1, 0.4, Con("LULCyear2005_2006_500m_Raster" == 78 & "soilRaster_reclass" == 1 & "slope_reclass" == 2, 0.5, Con("LULCyear2005_2006_500m_Raster" == 78 & "soilRaster_reclass" == 1 & "slope_reclass" == 3, 0.6, Con("LULCyear2005_2006_500m_Raster" == 78 & "soilRaster_reclass" == 2 & "slope_reclass" == 1, 0.1, Con("LULCyear2005_2006_500m_Raster" == 78 & "soilRaster_reclass" == 2 & "slope_reclass" == 3, 0.25, Con("LULCyear2005_2006_500m_Raster" == 78 & "soilRaster_reclass" == 2 & "slope_reclass" == 3, 0.3, Con("LULCyear2005_2006_500m_Raster" == 109, 0.41, Con("LULCyear2005_2006_500m_Raster" == 141,1))))))))))))))))))
Its for preparing a map with appropriate Runoff coefficient value based on Landuse, Slope and Soil type. Unfortunately, each time I run it I come accross this error message: Screenshot of error message
Please Help
ChrisDonohue__GISP
At first glance, I suspect the issue is the use of parenthesis.  Just an educated guess - wouldn't there be parenthesis at the end of the parameters for each CON statement instead of a pile of them at the end?
Con("LULCyear2005_2006_500m_Raster" == 1 & "soilRaster_reclass" == 1 & "slope_reclass" == 1, 0.5)
Con—Help | ArcGIS for Desktop
Building complex statements—ArcGIS Help | ArcGIS for Desktop
Chris Donohue, GISP
DarrenWiens2
MVP Honored Contributor
It is to do with parentheses, but in the sense that you need them to delineate consecutive Boolean expressions. From your link:
When using multiple Boolean (~, &, ^, |) and/or Relational (<, <=, >, >=, ==, !=) operators consecutively in a single expression, parentheses should be used. For example, parentheses are required in the following expression (a>2) & (a<5).
outRas = (Raster("a") > 2 ) & ( Raster("a") < 5)
So:
Con(("LULCyear2005_2006_500m_Raster" == 1) & ("soilRaster_reclass" == 1) & ("slope_reclass" == 1), 0.5, ...
JayantaPoddar
MVP Esteemed Contributor
Try putting the parentheses around the statements involving "=="
Con(("LULCyear2005_2006_500m_Raster" == 1) & ("soilRaster_reclass" == 1) & ("slope_reclass" == 1), 0.5, Con(("LULCyear2005_2006_500m_Raster" == 1) & ("soilRaster_reclass" == 1) & ("slope_reclass" == 2), 0.55...
Think Location
ChrisDonohue__GISP
Another idea - did the output raster assignment assignment get missed?  Or is it there but did not get copied over into your example?
Using the Con tool in Map Algebra
ArcGIS Help 10.1
Format:
OutRas = Con (in_conditional_raster, in_true_raster_or_constant, {in_false_raster_or_constant}, {where_clause})
Example:
OutRas = Con(SlopeRas, 10, 1, "VALUE < 15")
Chris Donohue, GISP
EDIT - looks like Darren and Jayanta likely have found the root cause while I was typing this.
DanPatterson_Retired
 A  Combine followed by a reclass is useful to avoid such ugly and error prone expressions... for next time
Combine—Help | ArcGIS for Desktop
