How to concatenate raster images in one representing value?
3606
17
08-11-2017 08:24 AM
AshrafAfana
New Contributor II
Hi all,
I'm trying to concatenate the values of two raster images in order to have a value that includes both of them (e.g. 02 + 07 = 0207). I'm trying to use the following in Raster Calculator "image1" & "" & "image2" but with no success.
any suggestions?
SteveLynch
IanMurray
Do your rasters have the same extent and cell size?
AshrafAfana
New Contributor II
Yes. Same resolution and same extension.
ChrisDonohue__GISP
Not sure if this will take you where you want to go, but I will throw it out there:
If 0207 is the desired output of rasters with values of 02 + 07, try multiplying the first raster by 100 before adding the raster values together.
Essentially:  (02*100) + 07
Chris Donohue, GISP
AshrafAfana
New Contributor II
Thanks Chris for the reply and for the simple idea. This should work with me. I thought ArcGIS can do it by converting the numbers to string character and concatenate them.
Thanks
DanPatterson_Retired
Rasters are represented by numbers ... 02 would suggest text... you can concatenate text, but not numbers. You won't get a preceeding 0 in 0207, the closest you will get is 207 as suggested by Chris.  Your end goal is therefore confusing
AshrafAfana
New Contributor II
Thanks Dan,
Absolutely agree, but I was using R where I can convert numeric to string character and concatenate them and I thought if there was away to do it directly in ArcGIS. Anyway, Chris suggestion was a valid solution.
Thanks
SteveLynch
have a look at Combine
AshrafAfana
New Contributor II
Thanks Steve,
But combine does not solve my problem.
curtvprice
MVP Esteemed Contributor
Raster datasets in ArcGIS do not contain strings for each cell, natively, the values in the raster are numbers. When there is a string value for a cell it is stored in a raster attribute table related to each value. (Only integer rasters can have such a  table.)
I disagree, I believe Steve Lynch is right on (as usual, Hi Steve) in suggesting Combine(): this is a more general solution as you could then a build a Calculate Field expression to populate a string field in the raster table with something that you want like "0207". One could do other encodings (to strings or numbers) by using a different Calculate Field expression.
1. Combine("ras1", "ras2")
The output will raster table will have two fields, RAS1 and RAS2, with a row for every unique combination (not every cell) and a COUNT of how many had that combination.
2. Add Field, "RCODE", "TEXT"
3. Calculate Field Python expression: "{:02}{:02}".format(!RAS1!, !RAS2!)
The RCODE field will be set to "0207" if RAS1=2 and RAS2=7 for that row.
