I moved a lot of Polygons while editing (now it has weird gaps and overlaps)
250
02-27-2024 05:03 AM
MarianaReyes
I have one giant polygon then I used the edit tool to slice and divide the areas to make different land types now it has weird gaps and overlands cause I accidentally moved a lot of polygons. What can I do to make it all fit? Thank you
MarkBoucher
There is this thing called "topology" that is used for this.
Basically, you
  • Create a geodatabase.
  • Create a new feature dataset in the geodatabase.
  • Copy or move the polygons as a feature class inside the feature dataset.
  • In that feature dataset, alongside the polygon feature class, create a new topology.
  • Onclude the feature dataset in it.
  • You then add rules for the dataset such as Must NotOverlap and Must not have gaps.
  • Then you validate it.
  • The result show you highlighted gaps and overlaps.
There are topology tools that allow you to decide what to do with the overlaps or gaps: that is to assign them to one side or the other of the overlap or gap.
Hope this makes sense and helps.
