Making a Density Map of a layer of points with Kernel Density Tool
734
09-22-2021 08:19 AM
Emily-Roberts
I am trying to take a layer of points and use the Kernel Density tool to make a point density heat map. I have successfully done this with several points layers, so I merged them into one layer and attempted again. Now I am getting the errors 010429 (twice--"Could not create tile" and "fail to open GRID"), 010296 ("Error in writing raster"), and 010067 (failed to execute). I have attempted making a new map and pulling the layers in, merging them again, and retrying. I've also tried correcting the projection and making sure there were no redundancies in the file names, etc. I'm not sure how to correct these errors--has anyone encountered this issue before?
JayantaPoddar
MVP Esteemed Contributor
Could you attempt saving the outut raster as a TIFF file (*.tif) in a basic folder (without space or special characters in filepath except underscore)?
Think Location
JayantaPoddar
Think Location
Emily-Roberts
This worked like a charm. Thank you!
