ModelBuilder- renaming of raster files during iterative model run
318
04-22-2013 03:42 PM
DanBlythe
I am using an iterative model to run a set of raster files (as list variables) through several tools, namely:
1. define projection
2. build attribute table
3. clip
4. project raster
5. resample
6. clip
7. calculate statistics
When the model reaches step 4 (Project Raster), it fails to execute. I identified the problem as being the numeric characters at the beginning of each filename in the intermediate dataset between steps 3 and 4; that is, the filenames that are output from step 3 (Clip) all begin with a number (e.g. 01_Clip.tif, 02_Clip.tip, 03_Clip.tif, etc.). These filenames were automatically generated by Model Builder when I built the model.
To remedy the problem, I manually changed each filename in that intermediate dataset, such that they end with a number (e.g. Clip_01.tif, Clip_02.tif, Clip_03.tif, etc.). However, as soon as I ran the model again, those filenames defaulted back to their original format, and the same problem occurred at step 4.
I am unsure of how to control the filenames if Model Builder automatically generates an unacceptable format at the start of each model run. Any suggestions would be greatly appreciated.
DanBlythe
3. clip
4. project raster
5. resample
6. clip
