Raster Calculator: Fill in NoData
24492
9
05-16-2011 06:33 AM
MarkCampbell1
I have a DEM that has missing points due to ponding water, how do I go into raster calculator and give the no data points a value, so I can fill them in with ArcHydro?
Thanks
Mark Campbell
TimothyHales
Esri Notable Contributor
Yeah, I'm pretty sure FocalMean does not work for ArcGIS 10.  Try a statement like this:
Con(IsNull(Raster), FocalStatistics(Raster, NbrCircle(10, "CELL"), "MEAN"), Raster)
TimothyHales
This has been answered on the following thread: Fill no data values areas in DEM
Within the Raster Calculator use a similar expression as below:
con(isnull(Raster_DEM), focalmean(Raster_DEM, rectangle,4,4), Raster_DEM)
This will look for the NoData values in the raster and for those locations find the focal mean. If the value is not
NoData then it will keep the value.
Li_ShuenNg1
Hi Timothy, I'm facing the same issue with a map that has no data values. Con(IsNull("raster"), FocalStatistics("raster", NbrRectangle(5,5, "CELL"), "MEAN"), "raster") is what I input, it worked but the map became coarser. How do I know which rectangle (e.g. "5,5") suits my data, in order to retain the original outlook in the first image? Here is the before and after.
MarkCampbell1
I tried:
Con(IsNull("DEM"), FocalMean("DEM",rectangle,4,4),"DEM")
FocalMean shows up as undefined,  Is it a problem that I am trying to run this in Arc 10?
Also, I couldn't find that link to the other thread,
Mark
TimothyHales
AriannaNumi
Dear Mr Hales,
where could I find a guide for the syntax for different types of neighborood? I am not sure about the meaning of the (10,''CELL'') in the expression you use; I can guess that it means a circle with a 10 cell radius? What are the alternatives to ''CELL''?
Thank you so much,
Arianna N.
TimothyHales
Hi Arianna Numi​,
The values in the syntax represent radius and units. You can get more explanation from ArcGIS Help | Focal Statistics
BarryGuidry
Mr. Hales, that worked great! I did only have to adjust the search value a bit for one of my grids to fully encompass the extracted building footprints.
lauriehogan
Q.  Does this fill all holes in the raster?  What if I only want to fill one hole and leave the rest alone - it seems a different approach/workflow is needed.  Appreciate any guidance you might have.  Thanks.
curtvprice
MVP Esteemed Contributor
As long as they are no farther across than the neighborhood kernel provided to FocalStatistics.
You can to extract the rectangular area of of the raster you want to modify, run the FocalStatistics operation, (or some other approach, for example, Nibble), and then paste it back in using the Mosaic tool.
