Raster Catalog
4761
10
02-17-2015 03:16 AM
JodieParkes1
I currently have a number of raster catalogs that I want to clip and export as TIFF files however everything I seem to try leads to '(Not responding)'.
So far, I have tried 'mosaic raster catalog...' and the 'Export data...' both of which seem to work for a while and then my document crashes.
Any tips/suggestions?
Thanks in advance
JakeSkinner
Esri Esteemed Contributor
Since you found the source images, I would recommend creating a mosaic dataset.  You can then apply a clip function to the mosaic dataset to get your end result.  Optionally, you can export this to another raster format.
JayantaPoddar
Hi Jodie,
Try running the process with the background processing disabled.
Geoprocessing > Geoprocessing Options > Background Geoprocessing (Uncheck Enable) > OK
Let me know the status of the issue.
Jay
Think Location
JodieParkes1
Hi Jay,
Nope still not responding. Do you know of any way I can clip a raster catalog?
Jodie
JakeSkinner
Hi Jodie,
Is the Raster Catalog managed or unmanaged?  If you right-click on the raster catalog in the Catalog window > Properties > Fields tab > select the Raster field.  It will then state whether it's managed (YES) or unmanaged (NO).  Ex:
JodieParkes1
HI Jake,
There's actually no mention of if the raster catalog is managed (see below). Is this the issue?
JakeSkinner
You will need to click on the Raster field (3rd from the bottom) within this window.
JodieParkes1
Got it - yes it is managed by GDB...
JakeSkinner
Try the following:
1.  Add the raster catalog to ArcMap
2.  Open the attribute table and select one of the rasters
3.  Right-click on the raster catalog > Data > Mosaic Raster Catalog
4.  Check 'Use selected rasters' at the top and right the raster to a TIFF file
Does the application still crash?
JodieParkes1
Hi Jake, sorry for the delay.
I've just given your suggestion a whirl and still no joy!
I'm not sure how to move forward on this one. I have now found the source of the images that make up the raster catalog and when I have added them in (TIFF format) I cannot merge and clip them either! This box comes up each time...
JakeSkinner
