You should be able to do it using zonal statistics under the spatial analyst. If you are looking for any occurence of a particular value that won't necessarily be seen in the statistics (not min, max, etc.) then create a raster where the value is 1 where the value of the original raster is the one you are interested in and 0 everywhere else, then use max.
