I am dabbling with the resolution of the error says RuntimeError: ERROR 010240: Could not save raster dataset to
as attached as a screen shot. I am working with a DEM file and trying to generate raster based on the conditional values from an excel file. As the excel file has about 15000 row, I need to generate about 15000 raster. I am very much disappointed when the script takes long time and at last it fails every time at different point and this has been happening from the yesterday.
I am just reading date and associated 3 temperature values from the excel file and applying con operation on DEM arcgis grid raster to generate another raster. This process is repeated for all the dates i.e. rows in the excel file as attached.
My script is a below
#!/usr/bin/python
# -*- coding: utf-8 -*-
import arcpy
import os
import sys
import shutil
from arcpy.sa import Con
from arcpy.sa import Raster
from openpyxl import load_workbook
arcpy.CheckOutExtension('spatial')
INPUT_TEMP_EXCEL_PATH = \
r"C:\Users\Winrock\Desktop\Ryan\Sept02ModularApproach\Temperature Model Data.xlsx" # arcpy.GetParameterAsText(0)
INPUT_DEM_RASTER_PATH = \
r"C:\Users\Winrock\Desktop\Ryan\Sept02ModularApproach\DEM\dem_clip_11" # arcpy.GetParameterAsText(1)
Second_Discrete_variable = 10 # arcpy.GetParameterAsText(2)
OUTPUT_TEMP_RASTER_FOLDER = \
r"C:\Users\Winrock\Desktop\Ryan\Sept02ModularApproach\OutputRaster" # arcpy.GetParameterAsText(3)
TEMP_FOLDER_PATH = \
r"C:\Users\Winrock\Desktop\Ryan\Sept02ModularApproach\Temp" # arcpy.GetParameterAsText(4)
Second_Discrete_variable = float(Second_Discrete_variable)
Temp_Data = []
# Loading temperature data
temp_wb = load_workbook(filename=INPUT_TEMP_EXCEL_PATH, read_only=True)
temp_ws = temp_wb[temp_wb.sheetnames[0]]
for row in temp_ws.rows:
rw = [cell.value for cell in row]
Temp_Data.append(rw)
Temp_Data = Temp_Data[1:]
# Folder content deleter
def folder_content_deleter(folder_path):
for the_file in os.listdir(folder_path):
file_path = os.path.join(folder_path, the_file)
try:
if os.path.isfile(file_path):
os.unlink(file_path)
elif os.path.isdir(file_path):
shutil.rmtree(file_path)
except Exception, e:
pass
# set temporary places, grid format needs a gdb for placing intermediate data
folder_content_deleter(TEMP_FOLDER_PATH)
arcpy.CreateFileGDB_management(out_folder_path=TEMP_FOLDER_PATH,
out_name='ScratchData_solRaster',
out_version='CURRENT')
arcpy.env.workspace = arcpy.env.scratchWorkspace = \
os.path.join(TEMP_FOLDER_PATH, 'ScratchData_solRaster.gdb')
# processing Second part
for tdata in Temp_Data:
T1 = tdata[1]
T2 = tdata[2]
T3 = tdata[3]
output_second = Con(Raster(INPUT_DEM_RASTER_PATH) < 2573, T1,
Con(Raster(INPUT_DEM_RASTER_PATH) <= 2754, T2,
T3))
final_temp_raster = output_second + Second_Discrete_variable
# save
out_path = os.path.join(OUTPUT_TEMP_RASTER_FOLDER, str(tdata[0]))
final_temp_raster.save(out_path)
# Cleaning
if arcpy.Exists('in_memory'):
arcpy.Delete_management('in_memory')
My error in gist is-
RuntimeError: ERROR 010240: Could not save raster dataset to C:\Users\Winrock\Desktop\Ryan\Sept02ModularApproach\Temp\ScratchData_solRaster.gdb\ifthe_ras with output format FGDBR
The excel file I am using is https://www.dropbox.com/s/qacfhipo4ry7o2b/Temperature%20Model%20Data.xlsx?dl=0
My error-
N.B. I tried several thread some of them are-
System specification:
Update:
*I tried with different scratch and current workspace
*I tried with arcpy.gp.Times_sa(it stops after processing almost 3000 rasters) and arcpy.sa.Times(it stops after processing almost 1070 rasters)
*I tried with arcpy.TestSchemaLock
*I tried with setting output to tif format too.
I see that it stops and raises error when it processed and output exact number of 1070 grid files.
It is giving me pain for several days- please help!
Thanks all Dan and Xander,
Al last I solved the problem!
My understanding that solved the problem:
My understanding about arcpy in raster processing at least in their grid format:
Below is my script so far:
#!/usr/bin/python
#Author:Shariful Islam
#Contact: msi_g@yahoo.com
import arcpy,os,shutil,multiprocessing,re
arcpy.CheckOutExtension("spatial")
try:
except:
raise Exception("install the openpyxl module in your python system")
#change below as it suits your system. try to make short all path below e.g. C:\OutputRsater D:\InputTempFile.xlsx
#just change the paths i.e. right side of the equations below nothing else- be careful.
INPUT_TEMP_EXCEL_PATH = r"C:\test\Temprt1.xlsx"
INPUT_DEM_RASTER_PATH = r"C:\test\dem_clip_11"
OUTPUT_TEMP_RASTER_FOLDER = r"C:\test\myout1"
TEMP_FOLDER_PATH = r"C:\test\mytemp"
#do not change below from here
Temp_Data = []
#Loading temperature data
d = []
if len(row)>3:
for cell in row:
if cell.value == None:
pass
elif cell.value == 0:
d.append(0.000000)
elif isinstance(cell.value, float):
d.append(round(cell.value,6))
else:
d.append(cell.value)
Temp_Data.append(d)
#process collected excel data
Temp_Data= Temp_Data[1:]
seen = set()
Temp_Data = [x for x in Temp_Data if x[0] not in seen and not seen.add(x[0])]# removing duplicate date
#Folder content deleter
try:
elif os.path.isdir(file_path): shutil.rmtree(file_path)
except Exception as e:
pass
#folder deleter
def purge(dirpth, pattern):
for f in os.listdir(dirpth):
if re.search(pattern, f):
pth = os.path.join(dirpth, f)
shutil.rmtree(pth, ignore_errors=True)
#gdb content deleter
def gdb_content_deleter(wrkspc):
for r,d,fls in arcpy.da.Walk(wrkspc, datatype="FeatureClass"):
for f in fls:
print f
try:
arcpy.Delete_management(os.path.join(r,f))
except:
pass
#copy and group by year
def grouperByYear(input_folder_path, output_folder_path):
for dirpath, dirnames, filenames in arcpy.da.Walk(input_folder_path, topdown=True, datatype="RasterDataset", type="GRID"):
for filename in filenames:
out_folder_name = re.findall(r'(?<=\g)\d{4}', filename)[0]
out_folder_path = os.path.join(output_folder_path,out_folder_name)
if not os.path.exists(out_folder_path):
print "Creating and populating folder for year %s ......"%out_folder_name
os.mkdir(out_folder_path)
in_data = os.path.join(dirpath,filename)
ou_feature_name = 'g'+re.findall(r'(?<=\g\d{4})\d{4}$',filename)[0]
out_data = os.path.join(out_folder_path,ou_feature_name)
arcpy.Copy_management(in_data, out_data)
#processing Second part
def times_worker(times_range_list):
#set temporary places, grid format needs a gdb for placing intermediate data
#folder_content_deleter(TEMP_FOLDER_PATH)
scratch_db_name = "Scratch_"+str(times_range_list[0][0])
arcpy.CreateFileGDB_management(out_folder_path=TEMP_FOLDER_PATH, out_name=scratch_db_name, out_version="CURRENT")
scr_db = os.path.join(TEMP_FOLDER_PATH,scratch_db_name+".gdb")
arcpy.env.scratchWorkspace = scr_db
#set output db
out_db_name = "RData_"+str(times_range_list[0][0])
#arcpy.CreateFileGDB_management(out_folder_path=OUTPUT_TEMP_RASTER_FOLDER, out_name=out_db_name, out_version="CURRENT")
#out_db = os.path.join(OUTPUT_TEMP_RASTER_FOLDER,out_db_name+".gdb")
out_db = os.path.join(OUTPUT_TEMP_RASTER_FOLDER,out_db_name)
if not os.path.exists(out_db):os.mkdir(out_db)
arcpy.env.workspace = out_db
for tdata in times_range_list:
T1 = float('%.6f'%tdata[1])
T2 = float('%.6f'%tdata[2])
T3 = float('%.6f'%tdata[3])
out_path = os.path.join(out_db,'g'+str(tdata[0]))
outRast_name = "in_memory\\%s"%out_db_name
arcpy.MakeRasterLayer_management(INPUT_DEM_RASTER_PATH,outRast_name)
output_second = Con(Raster(outRast_name)<2573,T1,Con(Raster(outRast_name)<=2754,T2,T3))
#save
#cleaning
gdb_content_deleter(scr_db)
def main(cu, worker, d_range):
pool = multiprocessing.Pool(cu)
pool.map(worker,d_range,1)
pool.close()
pool.join()
if __name__ == '__main__':
core_usage = 5
chunk_size = 1000
needed_cpu = int(round((len(Temp_Data)/chunk_size),0)+1)
offsetter = list(divmod(needed_cpu, core_usage))
cpu_distribution = [core_usage]*offsetter[0]+[offsetter[1]]
cpu_distribution = [cp for cp in cpu_distribution if cp!=0]#just remove zero
temp_data_range = [Temp_Data[i:i+chunk_size] for i in range(0,len(Temp_Data),chunk_size)]
print r"Doing raster math. It may take upto 3-7 hours even and may use your cpu at the heighest.\
So stop using your cpu fo this time. Go and enjoy elsewhere, let me do the job for you!.........."
loopcnt = 0
for cpu in cpu_distribution:
temp_data_range_splitted = temp_data_range[loopcnt:loopcnt+cpu]
if len(temp_data_range_splitted)>0:
main(cpu, times_worker, temp_data_range_splitted)
loopcnt+=cpu
#Cleaning
if arcpy.Exists("in_memory"):
arcpy.Delete_management("in_memory")
#group by year
print "\nGrouping raster math output by year for you. It may take 1-2 hours at best.So stay tuned!........\n"
grouperByYear(OUTPUT_TEMP_RASTER_FOLDER, OUTPUT_TEMP_RASTER_FOLDER)
#delete unnecessary folders
print "\nCleaning all unnecessary files........\n"
purge(OUTPUT_TEMP_RASTER_FOLDER, r'RData_[0-9]{8}')
print r"All job finished! Now you are ready for the processing:)"
you are being overly optimistic in processing that many rasters within the 4 GB limits without deleting stuff as you go. As a suggestion, I would get the spreadsheet into an alternate readable format and dispense with its overhead. As well you path is long and potentially causing problems... try something simple like c:\test and a shorter grid name... it appears you are using grids which have specific filename requirements, so try 'X' or if you want to use another format 'X.tif'. Keep things simple .... process in smaller batches ... switch to 64 bit background processing if possible or more to python 3.4.x and arcgis pro if you want to use all your available memory rather than tiling or processing in batches.
Try some of the above, monitor your system resources as you go, and you will narrow down your issue. You could profile your script to find out where memory is being consumed (there are modules in the Anaconda distribution for ArcGIS Pro 1.3 that will help with this.)... Good luck.
I would definitely store the Excel data in a table (fgdb) and also trying to store 15000 grids in a single folder will certainly yield errors. Also avoid long folder structures and name the output raster to be sure that the output name does not exceed limits.
The number of rasters isn't the issue ( https://community.esri.com/thread/173806 ).
It is file management, you aren't cleaning up as you go and as Xander points out... storing 15000 grids... do you really need them all and do you need them all at once???
The one thing you failed to mention is whether you ran it in steps... bites, portions... then append the pieces or work with their resultant.
Thanks Dan!
At last I tried to implement some of your advice. Is there any problem to read excel into a list and using this list later in the geoprocessing? I transferred all in root folder and tried to delete all the intermediate files after it is being used. I tried to save rasters as tif file and checked if align with the naming convention. In fact each raster name length is 8 e.g. 19120205 .But all with no success.
import arcpy,os,sys,shutil,time,csv from arcpy.sa import Con from arcpy.sa import Raster from openpyxl import load_workbook arcpy.env.overwriteOutput = True arcpy.CheckOutExtension("spatial") INPUT_TEMP_EXCEL_PATH = (#arcpy.GetParameterAsText(0) r"C:\test\Temprt.xlsx" ) INPUT_DEM_RASTER_PATH = (#arcpy.GetParameterAsText(1) r"C:\test\dem_clip_11" ) Second_Discrete_variable = (#arcpy.GetParameterAsText(2) 1 ) OUTPUT_TEMP_RASTER_FOLDER = (#arcpy.GetParameterAsText(3) r"C:\test\myout" ) TEMP_FOLDER_PATH = (#arcpy.GetParameterAsText(4) r"C:\test\mytemp" ) Second_Discrete_variable = float('%.6f'%Second_Discrete_variable) Temp_Data = [] #Loading temperature data temp_wb = load_workbook(filename=INPUT_TEMP_EXCEL_PATH, read_only=True) temp_ws = temp_wb[temp_wb.sheetnames[0]] for row in temp_ws.rows: d = [] for cell in row: if cell.value == None: pass elif cell.value == 0: d.append(0.000000) elif isinstance(cell.value, float): d.append(round(cell.value,6)) else: d.append(cell.value) Temp_Data.append(d) #process collected excel data Temp_Data= Temp_Data[1:] seen = set() Temp_Data = [x for x in Temp_Data if x[0] not in seen and not seen.add(x[0])]# removing duplicate date #Folder content deleter def folder_content_deleter(folder_path): for the_file in os.listdir(folder_path): file_path = os.path.join(folder_path, the_file) try: if os.path.isfile(file_path): os.unlink(file_path) elif os.path.isdir(file_path): shutil.rmtree(file_path) except Exception as e: pass #gdb content deleter def gdb_content_deleter(wrkspc): for r,d,fls in arcpy.da.Walk(wrkspc, datatype="FeatureClass"): for f in fls: print f try: arcpy.Delete_management(os.path.join(r,f)) print "deleted scratch" except: pass #set temporary places, grid format needs a gdb for placing intermediate data folder_content_deleter(TEMP_FOLDER_PATH) arcpy.CreateFileGDB_management(out_folder_path=TEMP_FOLDER_PATH, out_name="SDB_SR", out_version="CURRENT") scr_db = os.path.join(TEMP_FOLDER_PATH,"SDB_SR.gdb") arcpy.env.scratchWorkspace = scr_db #processing Second part counter = 0 for tdata in Temp_Data: T1 = float('%.6f'%tdata[1]) T2 = float('%.6f'%tdata[2]) T3 = float('%.6f'%tdata[3]) out_folder_name = str(tdata[0])[0:4] out_folder = os.path.join(OUTPUT_TEMP_RASTER_FOLDER,out_folder_name) if not os.path.exists(out_folder):os.mkdir(out_folder) arcpy.env.workspace = out_folder out_path = os.path.join(out_folder,str(tdata[0])+'.tif') output_second = Con(Raster(INPUT_DEM_RASTER_PATH)<2573,T1,Con(Raster(INPUT_DEM_RASTER_PATH)<=2754,T2,T3)) #apply map algebra if feature exists try: final_temp_raster = arcpy.gp.Times_sa(output_second, str(Second_Discrete_variable), "in_memory\\test_"+str(counter)) qq = final_temp_raster.getoutput(0) qq=Raster(qq) final_temp_raster = qq except: pass try: #check if wait is of use time.sleep(15) final_temp_raster = arcpy.gp.Times_sa(output_second, str(Second_Discrete_variable), "in_memory\\test_"+str(counter)) qq = final_temp_raster.getoutput(0) qq=Raster(qq) final_temp_raster = qq except: pass with open(os.path.join(TEMP_FOLDER_PATH,'error.csv'), 'ab') as error_file: writr = csv.writer(error_file) writr.writerow(tdata) counter+=1 #save final_temp_raster.save(out_path) #cleaning if arcpy.Exists("in_memory"): arcpy.Delete_management("in_memory") gdb_content_deleter(scr_db) #Cleaning if arcpy.Exists("in_memory"): arcpy.Delete_management("in_memory") folder_content_deleter(TEMP_FOLDER_PATH)
/blogs/dan_patterson/2016/08/14/script-formatting
and I can't tell from the code, but grid names can't begin with a number
A copy of the full error message again
There is no indication you have run it on fewer inputs..
also... can you add some print statements within the process to monitor what is being used as variable values and filenames
#!/usr/bin/python
try:
except:
Temp_Data = []
d = []
if len(row)>3:
for cell in row:
pass
d.append(0.000000)
else:
Temp_Data.append(d)
seen = set()
try:
pass
#folder deleter
for f in fls:
print f
try:
except:
pass
#set output db
#save
#cleaning
pool.close()
pool.join()
core_usage = 5
chunk_size = 1000
loopcnt = 0
loopcnt+=cpu
#Cleaning
#group by year
Wanted to add a comment.
Scratch rasters (those created with map algebra and not ".save()d") are piling up. Since all scratch rasters are grids (not .tifs) you are hitting the limit of 10,000 INFO tables (.vat, .bnd, .sta for each grid) in a workspace. I think you're getting around this by putting your scratch workspace into a .gdb, and multiprocessing, which puts every operation's temp rasters in their own workspace. (Setting scratch to file gdb means in many cases more file copying behind the scenes [grid to gdb] every time you create a raster. Even if this wasn't an issue, storing that many datasets of any kind of a folder is going to slow things WAY down as Arcpy needs to locate them whenever you browse the workspace. If your workflow avoided keeping so many temporary files around, I think it would go faster and you'd run into fewer issues.
Also see: The interaction of the Raster object—ArcGIS Help | ArcGIS for Desktop
