Spatial Analyst broken by script (ArcGIS 9.3)
530
11-07-2010 08:47 PM
markrobey
New Contributor III
I have a strange situation. The attached script runs from ArcCatalog many times without
a problem. However, there comes a time during a run when ArcGIS will say "ArcGIS has encountered a serious problem". After closing ArcGIS, Spatial Analyst does not work. No Spatial Analyst tool works.
This is the same on different PCs. Even after re-installing ArcGIS the problem is not solved.
Any ideas please?
Mark
markrobey
New Contributor III
Problem now seems to be solved. ArcGIS writes out a load of .nit and .dat files to a temporary folder.
Once I cleared these files out SA worked again.
