Working with kernel files in arcpy: NbrIrregular bug
3397
09-04-2014 12:03 PM
curtvprice
MVP Esteemed Contributor
When I try to use NbrIrregular in arcpy the tool fails:
>>> z = FocalStatistics("xg", NbrIrregular(r"D:\Users\cprice\work\scratch\x.txt"))
ERROR 010385: Invalid neighborhood type
I logged an incident with support and discovered this is a bug; fixed at 10.3:
[Bug NIM089705: The Focal Statistics tool in Python does not recognize the irregular neighborhood file using the NbrIrregular() object]
You can work around this problem by  using the text representation (I discovered this by using Copy As Python Snippet from the Results window:
NbrIrregular("Irregular <full_path_to_file>")
NbrIrregular("Irregular C:\kernels\ker.txt>") # for example
I think it's pretty weak that I have to write a kernel file in notepad too. I requested an enhancement, but in the meantime, here's a python function to make the process a little more convenient.
import arcpy
def NbrKernelFile(kernel="0 1 0; 1 1 1; 0 1 0", ktype="INTEGER"):
    """Create an ArcGIS Spatial Analyst kernel file
    example
      kerfile = NbrKernelFile("0 1 0;1 1 1;0 1 0")
      out_raster = arcpy.sa.FocalStatistics(in_raster, "Irregular {}".format(kerfile))
      arcpy.Delete_management(kerfile)
    note
    At 10.1/10.2 there is a bug, so we can't use NbrIrregular().
    The following code fails with ERROR 010385: Invalid neighborhood type:
    out_raster = arcpy.sa.FocalStatistics(in_raster, NbrIrregular(kerfile))
    the irregular neighborhood file using the NbrIrregular() object.
    Testing showed we could use this text representation, as used in
    the example above:
    "Irregular <full-path-to-kernel-file-no-quotes>"
    Curtis Price, cprice@usgs.gov, 2014/09/04
    # set up output file name
    out_file = arcpy.CreateScratchName(suffix="ker.txt" ,
                                       workspace=arcpy.env.scratchFolder)
    try:
        # process kernel text
        krows = kernel.split(";")
        if str(ktype)[:3].lower() == "int": ktype = "INTEGER"
        if ktype == "INTEGER":
            krows = [[str(int(k)) for k in krow.split()] for krow in krows]
        else:
            krows = [[str(float(k)) for k in krow.split()] for krow in krows]
        # check that we have an equal # of elements in each row
        ncols = len(krows[0])
        nrows = len(krows)
        for krow in krows:
            if len(krow) != ncols: raise
    except:
        raise Exception("Invalid kernel string: {0}".format(repr(kernel)))
    # write the kernel file
    try:
        kf = open(out_file, "w")
    except:
        raise Exception("Could not write file: {}".format(out_file))
    kf.write("{0} {1}\n".format(ncols, nrows))
    kf.writelines([" ".join(krow) + "\n" for krow in krows])
    kf.close()
    return out_file
CP - minor editorial changes
