ArcGIS StoryMaps Briefings App Updates
889
09-27-2023 07:59 PM
AdityaAllamraju1
The briefings app is a companion to your ArcGIS StoryMaps briefings. You can now access and share your briefings on the go from your iOS and Android tablets, and Windows computers and tablets providing a viewing, interacting, and presentation experience at your fingertips. For more information, please read our announcement blog article . 
 Please provide any feedback or issues encountered through the in-app feedback or Esri Community
What's New?
Here is the list of updates that have been added in the app version 1.3.5 for the April 25th, 2024 update :
  • Share slides with an interactive image gallery
  • Present animated GIF images animation in the slides
  • Improved user experience and app interface with consistent messaging when briefings are downloaded and added/removed to/from favorites.
Below is a list of issues you may encounter while using this release of the briefings app and a preview of what is planned for future releases. 
Known Issues and Limitations
We are aware of the following issues and plan to address them in an upcoming release.
IOS specific
  • A downloaded icon may show for non-downloaded briefings under the “All Briefings” tab only (Fixed in ver. 1.0)
  • Some special characters do not get encoded correctly in Briefing slide title and TOC (Fixed in ver. 1.0)
  • Video glyph beside the link to resource is missing and shows as space (Fixed in ver. 1.1.3)
  • GIF images do not animate and are shown as static image when added in logo or image block (Fixed in ver. 1.3.5)
  • Text shows single line and then truncates it on table of contents, and map pop-up identify for some cases
  • In some instances, when you pull down to refresh, the user interface may not update properly
  • Bold and italic styling is not yet supported in text blocks
  • When choosing recent used URLs in dark theme, the URL will appear dark for the first time
  • When the numbered list has 10+ items, the list gets pushed right giving some space in front of single digit items.
Android specific
  • There may be a lag when switching tabs, showing an empty screen instead of a graphic when there are no briefings to display. Please pull down to refresh if this occurs (Fixed in ver. 1.0)
  • Map tools have an offset placement issue (Fixed in ver. 1.0)
  • Tapping on the search bar in the map causes the briefings tablet app to crash (Fixed in ver. 1.0)
  • Some web scenes fail to expand correctly when clicking the expand button (Fixed in ver. 1.0)
  • Swipe block for maps do not have expand option (Fixed in ver. 1.0)
  • Scrolling within the embedded content view can interfere with the swiping gesture for the briefing slides (Fixed in ver.1.1.3)
  • Text shows single line and then truncates it on gallery card, table of contents and map pop-up identify (Fixed in ver. 1.3.5)
  • The screen may flash initially in the briefing slide before an embedded resource loads
  • If the images have a focus configured which is different from the default, it does not show the focus.
  • When web layers having embedded credentials are added in some IWA portal, the briefing shows Sign-in challenge.
  • All the items inside the numbered list always pushed to right giving some space in front of the text regardless of number of items.
Windows specific
  • There is UI sizing issue when windows screen is resized while inside briefing (Fixed in ver. 1.0)
  • Identify pop-up window in swipe block for express maps does not display (Fixed in ver. 1.0)
  • Some downloaded briefings show blank page on opening them and are not readable (Fixed in ver. 1.0)
  • Offline to online behavior does not display correct toast message in some cases (Fixed in ver. 1.0)
  • On clicking on My Briefings filter in disabled network, it shows offline empty state (Fixed in ver. 1.0)
  • Swipe block may have issues in the swiping gesture (Fixed in ver. 1.0)
  • Bold and color styling is not yet supported in text blocks (Fixed in ver. 1.1.3)
  • The sign-in button does not respond after signing browser has been closed without logging into the app. It would require restarting the app (Fixed in ver. 1.1.3)
  • Some special characters do not get encoded correctly in Briefing slide title and TOC (Fixed in ver. 1.1.3)
  • Scrolling through gallery cards has shadow effect while refreshing the items. (Fixed in ver.1.3.5)
  • Windows shows single line and then truncates the text on gallery card, TOC and map pop-up identify (Fixed in ver. 1.3.5)
  • After installing the app on some non-English language/locale environments, it may fail to launch. In this case please install the VC++ redistribution package from https://aka.ms/vs/17/release/vc_redist.x64.exe and then relaunch the app.   Alternatively, you can install the app on an English language/locale environment first and then switch to the non-English language and launch the app successfully.
  • Images in expanded view do not zoom in/out for non-touch devices only.
  • Windows always takes to cover page when minimizing and again maximizing the app.
  • There is UI issue with mouse wheel gestures while inside briefing.
General
  • The continue button on the sign-in dialogue does not get highlighted, but it is fully operational (Fixed in ver. 1.0)
  • Swipe blocks with maps are not yet supported (Fixed in ver. 1.0)
  • Some icons that are dark by default are not tinting properly at times (Fixed in ver. 1.0)
  • Some icons are not visible in the dark theme. Please use the light theme (Fixed in ver. 1.0)
  • Enterprise support is currently only for OAuth and SAML authorizations (Fixed in ver. 1.0)
  • Scene tools disappearing on slide view (Fixed in ver. 1.1.3)
  • One extra busy indicator appears on the gallery page when pulled down to refresh (Fixed in ver. 1.1.3)
  • Add to favorites / Remove from favorites does not respond in My Downloads tab (Fixed in ver. 1.1.3)
  • View full details does not redirect to the ArcGIS Online metadata page in My Downloads tab (Fixed in ver. 1.1.3)
  • App crashes when downloading a draft briefing (Fixed in ver. 1.1.3)
  • Icon tint issues on tapping download icon or any link to resource inside the briefing (Fixed in ver. 1.3.5)
  • Express maps in the web tier authentications like IWA, LDAP and PKI do not show the picture marker images in online briefings
  • Sign-in may fail the first time when using Facebook
  • You may experience an inability to sign out when signed in with a Gmail or GitHub account
  • Briefings using Google Fonts show the Summit theme fonts as the default
  • Scene layers within a legend for web scenes are not supported
  • 3D basemaps are not supported for web scenes
  • Popups with hyperlinks show as normal text
  • GIF images may not be sized as expected when added as resource link from ArcGIS content
  • Videos does not honor the theme background color
  • Image Gallery will always show maximum of 4 columns irrespective of single or double (30%, 50%, 70%) layout.
  • No pop-up displays when clicking a feature with Video info in Express map.
  • Images with Fit configuration having background and attribution is not honored when clicking a feature with media info in Express map.
What’s Coming
We are considering the following updates for future releases:
  • Update offline briefings
  • Search, and groups filter on the gallery page
