Within a Story Map Explorer map tour - there should be the ability to create a bulleted list. Currently you can do so outside the actual tour (see below). However, within the map tour itself there is no option. I'm trying to do a map tour of parks and wanted to do a bulleted list of all amenities present for each park. However, that is not a option. You also cannot copy/paste a bulleted list from another document nor even from within the same map to the map tour area. It will show up when you paste it -and say you saved it - but then it deletes it after you publish/refresh your map.
Thank you.
