Story Map with Polylines or Polygones
464
05-12-2014 06:43 AM
AntoineRICHARD
New Contributor II
Hello, is it possible to build a story map not only with a layer of points, but also with polylines and polygones layers ?
This will be better for the extents, scales and symbologies.
Best regards,thanks a lot.
Antoine Richard
3 Comments
EmilyLee
This would be a very good idea. Thank you!
OwenGeo
While you currently need to build a Map Tour with a point layer, you can add layers to your web map (which can be polygon or line layers).
See this blog post for details and some examples of this.
http://blogs.esri.com/esri/arcgis/2015/07/28/add-layers-to-your-map-tour/
NaomiBegg2
It's all very well showing polygon layer on the map of the story map ... but what we really need is to be able to have a record in the story map relating to each of the polygons and have it zoom and highlight the one that it is currently looking at.
