Tabulate Area help
4107
5
05-21-2014 05:12 PM
by Anonymous User
Not applicable
Original User: infadork
I am trying to tabulate area of a Land Use and Local Watershed, however when I put in the Local Watershed into the first input their is no option for Area, which I have in the table of the Local Watershed attributes. How do I go about accessing that data to tabulate the area?
The first picture is my attribute table which clearly shows Area as a column.
[ATTACH=CONFIG]33985[/ATTACH]
This second picture are my selectable attributes when under Tabulated Area.
[ATTACH=CONFIG]33984[/ATTACH]
How do I get the Area under the selectable attributes?
by Anonymous User
Not applicable
Original User: raymondhuang
Hi Adam,
The tool helps you tabulate the area based on your zones and produces a table out of it. Not sure if it is what you are expecting from the tool:
See here for more info: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000w2000000.htm
For your datasets, may I check if you are trying to find out the different types of landuse and their respective areas inside a watershed? Also, are your Landuse and Watershed datasets both rasters?
Hope those are correct guiding questions to help in your case. Let us know how it goes.
Regards,
Raymond
AdamBerlin
Raymond,
Pleased to see you again lol.
I looked on the forums and I found a way to calculate Percentage Land Use: http://forums.arcgis.com/threads/70779-arcmap-land-use-type-as-a-percentage-of-total-area
I am trying to find out the different percentages of land use within each local watershed. It is from there that I will be basing where I will sample water from along the river.
I have honestly no idea if both sets of data are rasters or not, but I would imagine the Land use is a raster and the watershed is not, but I could be wrong.
Anything else I can put in there to help you out?
by Anonymous User
Not applicable
Hi Adam,
Haha, nice to be 'chatting' again.
When, will it be convenient for you to post one or two screenshots of ArcMap showing your Table of Contents and the Catalog panel showing where your data is from?
Raymond
AdamBerlin
How about now?
[ATTACH=CONFIG]33986[/ATTACH]
I know I downloaded all of the appropriate geodatabase information from the following websites:
http://magic.lib.uconn.edu/connecticut_data.html and http://www.ct.gov/deep/cwp/view.asp?A=2698&Q=322898
by Anonymous User
Not applicable
Raymond,
Any word? I am seriously stuck ugh...
