Deploying Survey123 on premises is a great possibility, allowing organizations to keep all ESRI resources & traffic within the organization (for instance, this is a legal requirement for many governmental bodies outside the US).
Currently (oct-2019), the beta available on the ESRI Early Adopter Community (ref. here) lacks one of the major functionnalities: the ability to create feature reports, i.e. complete a MS word document model with attributes, attachments and location preview form the feature service.
With a on-premises deployment of Survey123, the only possibility is then to run simple merges between an MS Excel data extract and the word document. Attachments are not available, and location cannot be rendered as easily/directly: the report is much poorer than what can be done with Survey123.arcgis.com.
Please add feature reports to a not-so-distant future release of the Survey123 Enterprise (On-Premises) build!
Many thanks!!!
Hélène.
Kristen described our situation perfectly. In fact, a quick poll of our archeologists a few months ago showed nearly 60 of us using our portal for GNSS. The number continues to climb as those of us already using Survey123 tell others about it.
We also need a report for features collected with Field Maps. At this point, the only option is to convert the attribute tables to Excel, link from Access to populate a form that mimics the report format needed, then export that as a PDF.
Excellent news! Thanks for the update @JamesTedrick
Agreed! Excellent news indeed. @JamesTedrick
I agree and would like to see this functionality added to Survey123 Enterprise. I was very excited to find the feature report functionality in Survey123 and then let down to find that the functionality isn't completely available in Survey123 Enterprise.
Hi, we need this badly, any updates on the progress of having this functionality?
Thanks
This is a critical feature for us too.
Thanks
Currently under development. Earliest delivery in 2024.
Fantastic news! Good decision. Looking forward to implementation.
@IsmaelChivite thanks for the update.
Cheers bks
Hi @IsmaelChivite , @JamesTedrick
any update please?
