Idea: Enable Survey123 Connect users to specify the maxRecordCount parameter for feature layers directly within the application, providing more control over the number of records displayed in the survey inbox.
Background:
Currently, Survey123 users face limitations when querying records within the survey inbox. The default maxRecordCount is set to 1000, which might not be sufficient for larger surveys with extensive data. Developers often encounter challenges when they need to access more than 1000 records, leading to workarounds and complex solutions.
Proposal:
Integration in Survey123 Connect:
Benefits:
FYI You can hack it using this https://support.esri.com/en-us/knowledge-base/problem-unable-to-edit-the-maximum-record-count-for-fe...
