Be able to hide (or disable) the recalculate button that appears next to calculated fields.
There are certain instances/workflows where the presence of the recalculate button is undesirable and risks data entry or usability issues (e.g. here).
Hi @ColinCampbell1 ,
Ca you provide more details on the scenario where you are seeing the recalculate button with read only fields (as mentioned in the community discussion), potentially with an XLSX form example?
Additionally, have you used the once() function to prevent further calculation and are still seeing this issue?
