It is often required to have a unique id that is not a gloablid structure in reports so they can be linked to the service data and all other aspects of the information model that is semi human readible.
Objectid is always created against the layers but you are unable to use the ObjectID field in Feature report templates. It would be great if we could expose the Objectid and other system generated fields not created through Survey123 Connect or web designer to the FRTs
This is already a thing. It's ${objectid}, not ${ObjectID}
Thank You @abureaux . I could swear we tested this numerous times but I just double checked then and its working for us in certain scenarios but in others its getting failing to parse errors so we are trying to whittle it down to what is causing the issues.
