The workflow of adding/updating templates could be automated using the ArcGIS API for Python. Considering the number of surveys you have this could save time and effort in the long run. The usage of the Survey Manager is outlined in the following guide, see especially the section on using upload_report_template.
https://developers.arcgis.com/survey123/guide/create-reports-using-the-arcgis-api-for-python/
To use Notebooks in ArcGIS Online, you'll need to be either an Administrator or a custom role with the privilege to create and edit notebooks.
-Rylee
