ArcGIS Survey123 Read-only Question too greyed out
490
08-16-2023 06:17 AM
CMcDonald
Occasional Contributor II
Hello,
I have designed a survey with 3 Read-only questions which populate data via a Layer my Experience Builder App.  This is great having Survey123 built into Experience Builder but I feel the read only questions I have set are too greyed out.
I have experimented in the second question by asking people not to input data but this causes unnecessary clutter on the form I feel and could also mean values are changed.
Am I missing a setting here or workaround?
Thanks
Tags (1)
MobiusSnake
MVP
You might want to try using a Note question for this instead of a read-only textbox.
MobiusSnake
MVP
CMcDonald
Thanks, I think I understand.
If I set the Note to insert answer from another question that seems to work.  I then just hide the Question 🙂
