Hi Zach,
This is something I have tried, and it does work. I have been doing more testing between environments and noticed a few odd behaviors - maybe you have suggestions or know why this happens.
When moving a Flow from Dev to Prod, I use the Export package option. I then turn off/disable to Flow in Dev. When I Import and set up the Flow in Prod, it is turned off/disabled. When I turn it on, it also turns on the Flow in Dev. I am unsure if this is expected behavior, or if it is because I have named the Flow the same thing between Dev and Prod. It also resulted in duplicate email notifications when I submitted a test survey. The only way I could think to resolve this was to delete the Dev version. However, I am unsure if this is best practice.
Any thoughts?
Also, when sharing a Flow with someone, I noticed that the incorrect connections were listed. I use a service account for email generation, but the dialog said it was sharing my named account credentials (which aren't even used in the Flow, although my named account owns/authored the Flow).
Thank you,
Erica
