Hello,
I've used grid layouts in surveys before, and I thought I understood how they worked...not that complicated of a concept. But today I was trying to start a new survey and none of the grid settings were working. For instance, if I set a group to have appearance w6, and then the next two questions to have appearance of w3, (so that only those two questions would be on a single line), it doesn't change anything and the entire group still shows 6 questions per line.
I even opened the sample Grid Layouts survey, and when I look at the preview in Survey123 Connect it looks extremely "wonky".
This is what the preview looks like.
This is the XLS form it's based on, provided by Esri.
What's going on?
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
