I am developing a Survey123 form for habitat assessments which uses nested repeats to link species lists to each habitat polygon in a geotrace question (within the first repeat).
1) The main geotrace question records the site boundary
2) The first repeat geotrace question records each habitat parcel
3) The nested repeat records all species within each habitat parcel
While drawing habitat polygons on a survey it is important to be able to see all of the entered polygons for the previous repeat records so that boundaries of each habitat parcel can be aligned.
Question - Is it possible to display all polygons of each repeat record in the background of the geotrace question as they get added through the survey so the surveyor can see where they need to draw the next polygon on the map?
Thanks Josh
Solved! Go to Solution.
Hello @JoshB123,
We have an `overlay` parameter but unfortunately only supports geopoints at this time and does not work with geotrace/geoshape.
We have an internal issue to support geotrace/geoshape in the future. Please feel free to reach out to Esri Technical Support to log an Enhancement for this feature.
Hello @JoshB123,
