Without knowing exactly how you want to use that information, my first instinct would be to set it up as a cascading select: Cascading and external selects—Survey123 for ArcGIS | Documentation
You could even have a couple levels to it: first selection is the manufacturer, then the type, then the model. Since it's a pretty long list, I'd probably also make sure it's an external select (discussed on the same link) so that it doesn't slow down the survey load times too much.
