Embed Survey In Ops Dashboard
371
11-24-2021 06:35 AM
GaryBowles1
Is it possible to embed a Survey123 form in an Ops Dashboard if the Survey is created from a feature service in ArcGIS Enterprise and not a hosted feature service? I have a dashboard working with a hosted feature service survey, and when i crated a new dashboard for the 'non-hosted' feature service, i am getting the following error on the embedded Surevyer123 form:
viewing is not possible because the globalId parameter was not provided.
I have tried all variations of globalid syntax(GlobalID, globalID, etc.) and none worked. I am also just trying to view the record in the dashboard, no need to edit these.
Survey created with Connect, ArcGISEnterprise (Portal) 10.8.1
--gary
