I am trying to set up a power bi report that will allow the user to open and edit a submitted survey. I am able to get the survey to open but it does not open the individual survey.
Here is the URL I am using:
arcgis-survey123://?itemID=dc0...&mode=edit&portalUrl=https://gis.srcx.com/portal&globalId=46A...
We are using ArcGIS Enterprise 11.1
--gary
Solved! Go to Solution.
Where you have &globalid=46A..
Try making it &filter=globalid:46A..
As well, instead of mode=edit try making it action=edit
That's how I had to set it up for my parameters, give that a shot and see if it works?
What we have set up currently is:
https://survey123.arcgis.app/?itemID={itemdID}&action=edit&update=true&folder=*&filter=globalid:{globalID}
I think you need to add the filter= before the globalid.
Did you say it's opening from Power BI with that URL scheme? I was struggling with that the other day.
I am able to get Survey123 to open from a browser with the URL. I can't get it to open the individual survey that I am providing the globalId for.
--gary
Just to clarify, I am trying to embed a URL in a PowerBi dashboard that will open Survey123 to a specific survey that will be edited. I do not need to necessarily embed Survey123 in PowerBi.
--gary
Bingo! that worked.
Thanks for the assist.
--gary
